M30 ECU
johnl320
Post Sat Jan 20, 2007 7:57 pm
Having a small pile of ecu's on the shelf in the garage I have absolutely no Idea which one is for the M30. Lump and ecu came out of a E reg 735i auto. Can anyone help with this slight cock up on my behalf and supply the last three digits for the right one.
cheers
john
oze30
Post Sat Jan 20, 2007 9:50 pm
it should be the one with a yellow label.
I have 3 in the garage, 2 new and 1 old. H reg is yellow.. the other later models are red/brown?? (Colour blind!)
johnl320
Post Sat Jan 20, 2007 10:06 pm
One has deffo got a yellow label, I guess I'll try that one first :snigger:
cheers mate
john
Post Sat Jan 20, 2007 10:28 pm
'87 was a changeover year, just to complicate things a little!
87-88 should be 0261200150
84-87 should be 0261200061
bigdek
Post Sat Jan 20, 2007 10:32 pm
possibly a 179 as well i think
Post Sun Jan 21, 2007 12:04 am
bigdek wrote:possibly a 179 as well i think
179 is '89 on, and OP says 'E' reg, so I doubt it.
johnl320
Post Sun Jan 21, 2007 10:25 am
Thanks fellas, I've got a 150 in the pile so that must be the one :thumb:
john
Post Sat Jun 23, 2007 6:26 pm
A 179 (Motronic 1.3) ECU can be used as a direct plug & play swop for the earlier 150 (Motronic 1.1) ECU I've discovered; the 179 is far easier to chip, being a single-PCB unit :P
johnl320
Post Sat Jun 30, 2007 8:53 am
Any performance gains from using the newer ecu in standard form, smoothness, economy, power, etc?
john
Post Sat Jun 30, 2007 11:53 am
Yes, Motronic 1.3 has better resolution (more memory map locations), and is at least on my E34 535i, smoother running than the old Superchipped 150 ECU that I had (currently have the standard BMW chip in the 179 ECU, though I'll soon be trying a BBR chip)...
johnl320
Post Sat Jun 30, 2007 12:04 pm
thanks mate, I feel a scrap yard trolley dash coming on :wink:
john
Post Sat Jun 30, 2007 12:13 pm
Cool. If you can't find one there, I've had a couple of 179's off E-bay for around £20 a throw.
johnl320
Post Sat Jun 30, 2007 12:14 pm
:thumb:
