http://cgi.ebay.co.uk/BMW-M3-E36-BRAND- ... dZViewItem
Here is a nice cheap new rad. Is this the best one for me to use for my S50B32 engine conversion? The engine and associated pipework I have came from an earlier MCoupé.
What other options for the cooling system do I have? I like the idea of using an E36 6 pot radiator that has the expansion tank built in, to save space and tidy up the under-bonnet area. Is this an option?
Many thanks
Jai
Is this the best rad to use for S50 conversion?
jaistanley
buster
Thats the one i used. an m3 evo rad,fits perfectly.
Yes, yes and yes
I just commented about this rad in Jimbobs thread.
You cant get a better rad for the job
ian332isport
Although it may tidy things up, it also reduces the cooling capacity of the radiator (smaller core). It may work fine, but I personally wouldn't risk it.jaistanley wrote:I like the idea of using an E36 6 pot radiator that has the expansion tank built in, to save space and tidy up the under-bonnet area. Is this an option?
Stick with the proper rad for the job. BMW made it that size for a reason
Ian.
jaistanley
You've convinced me!
I'll order that come payday. Seems a reasonable price doesn't it? Not OEM quality I guess but I'm sure it'll do?
The header tank from my 325i is in minty McMint condition, can I use that in it's existing location and re-pipe the system to suit (ie is that what you guys did?)? The MRoadster the engine came out of had the header tank up where our servos are if I recall correctly.
Jai
Jai
ian332isport
I got mine from ECP, and it was a genuine BMW part. Someone had used a marker pen over the BMW logo on the label, but it was clearly genuine. I think the BMW ones are made by Behr in Germany (mine is).jaistanley wrote:Not OEM quality I guess but I'm sure it'll do?
YesThe header tank from my 325i is in minty McMint condition, can I use that in it's existing location and re-pipe the system to suit (ie is that what you guys did?)?
Ian.
