325 turbo starting problem
midnight
Disributor cap/rotor arm is most likely source of problem.
midnight
E30Mark
What ECU you running?
have you got a 24v supply??
PM for details
PM for details
midnight
Could be the damp weather. My mum's Rover 416SLi wouldn't start this week. The spark at the plugs was a nice fat one - but orange. The AA guy finally got it running by drying out the push on spark plug lead caps - he reckoned it was a common problem on Rover 100s.
midnight
Turbo-Brown
- Boost Junkie
Thought the EDIS did it's own ignition amplifying and was just told what to do by the MS?
E30Mark
I assume this coil pack transforms the 12V to 24V internally then...
Have you tried measuring the voltage to the coil pack whilst cranking the engine? my guess anything lower than 10V spells trouble.
Has it run with this coil pack? or is this a new addition?
PM for details
PM for details
kam-325i
Dose he mean "Mondeo V6 24 Valve", and not 24 Volts ????
E30Mark
At least there is one bright spark amongst us!kam-325i wrote:Dose he mean "Mondeo V6 24 Valve", and not 24 Volts ????
PM for details
PM for details
Saw this one earlier, Mark, but thought "I've already had a go at him today about the green/black starter wire; I'll let someone else pick this one up, or he'll think I'm picking on him". Take it you've started the New Year celebrations a bit early?
Turbo-Brown
- Boost Junkie
If it's anything like mine, the coil only gets battery voltage so it'll drop quite a bit on cranking as they're not ballasted
Have you checked your earths to the EDIS and coil pack?
The basic operation of the coils is so simple that (as a complete guess) a poor connection could cause the weak spark? There's drunken logic for ya
Ant
- Retired Team Member
what dwell settings are you using dude ?
Email FTW
midnight
ive checked all earths and connections, voltage the lot!
i done a bit of researchand found out that the coil im using requires quite a high dwell time, between 4-5 ms i know this is going to cause me problems in high revs getting a decent spark, but i just need it running guys, i can worry about sorting out a new coil pack at a later dat. i set the cranking dwell at 4.8 andf the running dwell at 4.2. i havent really had much luck with that either but setting at that
kam-325i
could it be a duff coil pack ?
midnight
kam-325i
Coil pack is producing spark, but weak......
Dwell is ok for cranking......
Coil pack getting signal ok...
Never over look the most simplist thing......
Im not to bright with coil packs......How do they work.....same as a ordianry coil with priamary/secondary windings ?
i can only think of poor coil pack or poor voltage at cranking........How about bad HT leads ?
Turbo-Brown
- Boost Junkie
Yeah coil packs work in exactly the same way as single coils, there's just more of them (actually I think there might be a difference in that one post will be anode and the other cathode) but the basic principal's the same.
Are you using an EDIS module Midnight or just the coil pack from an EDIS equipped car?
No idea what the EDIS modules do but as I understand it, they can switch to a limp home mode if the signal from the ECU fails so they must be reasonably complex bits of kit. Perhaps they just need a trigger signal and can take care of their own dwell settings or something?
midnight
Turbo-Brown
- Boost Junkie
It's 90degrees BTDC on the M20 for some reason.
Usually the Bosch 60-2 is at 120 degrees but BMW decided to change it for some reason
Gunni
FYI on later bmw´s it´s about 70 on 4cyls,
My M42 is 115.
My M42 is 115.
midnight
guys this wagon is still not having it, i got all the trigger angles sent to me and all the wheel decoder settings aswell, and i took the trigger wheel off to check the figures and they all seem right, and im getting a good spark, compression is fine and im getting fuel delivery aswell, but one thing i cant get my head around is that when it turning over trying to start and it will splutter and try to go for it, it seems to splutter back through the air filter in stead of the exhaust, bearing in mid all the timing is all fine and valve clearences are all fine aswell.
any help is much appreciated, because im at the point i cant even think anymore, this car has caused me too much strees, i just dont know whats going on with it?...........................
Andy335Touring
If you can't sort it your self then see if Ant will fix it for you ?
He's a top bloke, done plenty of M/S and Turbo installs.
Mind, i don't know how far away Ant is from you though ?
midnight
Andy335Touring
midnight
Ant
PM replied to, sorry dude, I do get busy
Email FTW
midnight
