im interested in this 2.8 conversion . so far i know its the e36 2.8 crank which needs a collar makin up to house, hold crank. then 320 pistons and rods. does this seem about right???
e30 2.8
m-dtech
- Unapproved Trader caution
why not just drop in the e36 m52 2.8??
bmwonly
coz i wanna keep it E30. and its different. and it'llbe a shit load cheaper
e30_Turbo
- Boost Junkie
Been done a few times on here actually, not as potent as you may think.bmwonly wrote:coz i wanna keep it E30. and its different. and it'llbe a shit load cheaper
I'd go for the 2.8 engine as is, 24v, 240/250bhp poss too, you won't get that outta a m20 with spending £6/7k+
Or fit a turbo, but then again I am biased
Andyboy (Andrew Everret) knows his stuff, and has been posting on this recently. Do a forum search.bmwonly wrote:im interested in this 2.8 conversion . so far i know its the e36 2.8 crank which needs a collar makin up to house, hold crank. then 320 pistons and rods. does this seem about right???
oze30
Considering the costs involved with the m50.. manifold work, gearbox, diff, prop, you'd be better off with the (cost wise) 2.8i reckon.. or a 3.5!fozzymonster wrote:Been done a few times on here actually, not as potent as you may think.bmwonly wrote:coz i wanna keep it E30. and its different. and it'llbe a shit load cheaper
Andyboy
- Alpina Colada
325i or Eta block. 2.8 crank with a collar made up. Standard M52 crank bolt shortened by 2mm. 320i/Eta rods and late (short skirt) 325i pistons. Then just screw it together, no other machining needed.
As for power, it will always give a bit more power and torque than a comparable 2.7. It's a nicer conversion because you don't need to skim the block or piss about with vernier cam pulleys. A new crank with shells from BMW is about £540+vat but a shagged short engine with bore wear or stripped threads a lot less.
Cranks are exchange so you'd give BMW your old 325i crank back
. Most dealers will give 10% off this making a lovely new crank with shells £571. Not bad!
