which spark plugs?
blingsta
Boost Junkie
Post Wed Dec 06, 2006 11:12 pm
Guys, can anyone tell me what plugs to use for a 325i turbo? would it still be normal plugs for a 325i?
e30_Turbo
Boost Junkie
Post Wed Dec 06, 2006 11:32 pm
You can go colder by a few degree's but there is no evidence so far that it helps. Stock have been fine for me even tho I did run colder for a few months with no ill effects.
Borrowed from e30tech:
Q: What plugs should i use? what should i gap them to?
A: NGK 3923 BPR8ES plugs. Their 3 degrees colder than stock. i gap them to .025". For 1.0 bar or more boost, even colder plugs are recommended (BPR7ES).
Turbo-Brown
Boost Junkie
Post Thu Dec 07, 2006 7:59 am
Awwwww, look at the puny gap they run :D
e30_Turbo
Boost Junkie
Post Thu Dec 07, 2006 11:05 am
Turbo-Brown wrote:Awwwww, look at the puny gap they run :D
I know, I'm so looking forward to 0.9!!
I've set mine at .5 for now, maygo back to .2 if everything else checks out. ( I'm going through everything again to trace this bastard earth issue )
Mark.
carpmart
Post Thu Dec 07, 2006 7:01 pm
I have always found plug gaps to be sensitive on turbo cars and run 0.5 mm on my pinto turbo with no problems. I actually need a heat range in between what is available as the cold plugs foul easily and the warmer ones are not quite right! oh well, the challenges we face!
blingsta
Boost Junkie
Post Thu Dec 07, 2006 7:08 pm
i know their expensive, but hows about iridiums ?
Demlotcrew
Post Thu Dec 07, 2006 7:14 pm
I use iridium plugs and i think they are great! But i dont have a turbo car.
Andrew
Turbo-Brown
Boost Junkie
Post Thu Dec 07, 2006 7:15 pm
Nuts to that, more coils is what you need :D
blingsta
Boost Junkie
Post Thu Dec 07, 2006 7:30 pm
Yeah so ive heard, but apparently you lose the rev counter !?
Turbo-Brown
Boost Junkie
Post Thu Dec 07, 2006 7:51 pm
Shouldn't do!
The ECU tells the rev counter to work and seperately tells the coils to do their thing :)
Mine certainly works with three coils generating juicy fat sparks :D
blingsta
Boost Junkie
Post Thu Dec 07, 2006 8:32 pm
Oh. !! i was told that it doesnt work... are you using m/s too? im gonna have to check again with Ant
Turbo-Brown
Boost Junkie
Post Thu Dec 07, 2006 8:36 pm
Nay lad, I'm on Emerald. Seems odd that you'd lose the tacho output just because you've added a couple of extra ignition drivers, but then I don't know anything about MS so mabey you do :(
Demlotcrew
Post Thu Dec 07, 2006 8:40 pm
You need to keep the motronic in the car to run the tacho if you go MS.
Andrew
blingsta
Boost Junkie
Post Thu Dec 07, 2006 8:44 pm
Demlotcrew wrote:You need to keep the motronic in the car to run the tacho if you go MS.
Andrew
yep, the old motronic is still there !! only to control rev counter, dont think theres any way round this.. yet!!
gcorky
Boost Junkie
Post Thu Dec 07, 2006 8:50 pm
think the tach signal is fettled for ms ?
You'll be able to keep everything except the fuel economy gauge. Megasquirt has a tach output pin, which sends a signal that you can directly connect to the ALL BLACK wire that goes to the gauge cluster, it is PIN 6 on the motronic connector. I have the JS1 on the v3 board go to it, and it works perfectly.
525 sport
blingsta
Boost Junkie
Post Thu Dec 07, 2006 8:51 pm
gcorky wrote:think the tach signal is fettled for ms ?
what does that mean mate? :(
Turbo-Brown
Boost Junkie
Post Thu Dec 07, 2006 10:10 pm
It's just a square wave 5v signal as far as I'm aware.
I can't believe that MS doesn't have an output for a tacho and the 5v thing seems to be pretty standard, either that or the back EMF off the coil that Pug and VW used to use which you need a signal convertor to get from 5v to 300v, but the BMW doesn't need that :)
e30_Turbo
Boost Junkie
Post Fri Dec 08, 2006 8:56 am
Andrew
Utter bollox.
MS has a tach output feature, I have it enabled myself, as does Ant, Blingsta, Mattg etc.....
What we don't have is a way to convert MS output to the correct voltage to run the tacho. Alex has cracked it on emerald so now it's MS's turn.
Ant also mentioned that for some reason the swap over to wasted kills the moronic tacho feed anyway, so tach output or nothing!
Some yanks have it working and I'm gonna go see what is what when I have some revs to use :cool:
HTH, Mark.
blingsta
Boost Junkie
Post Fri Dec 08, 2006 1:07 pm
Im awaiting your findings Marks... bottle of bubbly if you can crack it mate.. :D
Toby_Unna
Boost Junkie
Post Fri Dec 08, 2006 1:19 pm
Andrew
well there's no motronic anywhere in my car and the tacho works fine thanks :roll:
Turbo-Brown
Boost Junkie
Post Fri Dec 08, 2006 2:05 pm
Pretty sure that the 5v SQ wave signal is just about the most common tacho input there is and as that's what my ECU puts out, and as my tacho works just fine, I reckon that's what the tacho's expecting.
Take it you don't get a tacho tell-tale with the MS?
Mine tells you how naughty you've been if you leave the key in the accessory position by moving the tacho needle to whatever your max revs have been :)
Toby_Unna
Boost Junkie
Post Fri Dec 08, 2006 2:15 pm
no, but i've seen Andy's Emerald 335 touring do so, very cool :D
back on topic slightly, i have standard bosch plugs in mine and they're gapped to whatever they were when i bought them 2 years ago :?
seems happy enough at 7psi anyway.
