m40b16 into a 320i(m20b20)
michael24m
Wed Nov 22, 2006 11:42 pm
i'm going to do this swap for the better economy of city travel:D
i'm planning to put the m40b16 engine from a '89 316i into a '84 320i (le-jetronic).
what modification is needed for the electrical side of the story? i have the complete m40 engine, complete with electrics and all.
is this a relatively easy modification?
i also would want my diagnostics plug to work after the mod.
awaiting for your advice!
thanks!
m-dtech
Unapproved Trader caution
Wed Nov 22, 2006 11:55 pm
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
you will need gearbox and prop too
electrics are easy
michael24m
Thu Nov 23, 2006 12:36 pm
i have the whole 316i donor car, so prop, no problem. i will also need the differential?
is this modification worth it?
what do you think?
Morat
Thu Nov 23, 2006 1:25 pm
why not upgrade to MS on your existing engine?
m-dtech
Thu Nov 23, 2006 1:31 pm
MS wont do much on a flat top IMO
if fuel economy is a problem then BMW is the wrong car for you.
michael24m
Thu Nov 23, 2006 3:55 pm
will i also need the differential fitted from the 316i for this mod?
cliffybabe
Powered by Nelly
Powered by Nelly
Thu Nov 23, 2006 4:00 pm
yep ur need th ediff aswell mate :cool:
bmwe30mtech
Thu Nov 23, 2006 4:14 pm
The M40 has a crap economy, it wont be much better, if any, than the 320i (amazingly). The M40 isnt great when it comes to mpg, noise etc. (im allowed to put it down, i have one).
Maybe you dont want a BMW, maybe a corsa....
cliffybabe
Powered by Nelly
Powered by Nelly
Thu Nov 23, 2006 4:30 pm
bmwe30mtech wrote:The M40 has a crap economy, it wont be much better, if any, than the 320i (amazingly). The M40 isnt great when it comes to mpg, noise etc. (im allowed to put it down, i have one).
yeah i can vouch for pauls statment i have seen him in action on the motorway, well did see him in action until we all left him winkeye
bmwe30mtech
Thu Nov 23, 2006 4:56 pm
You were well into the three figure speeds mate....m40 wont go much over the indicated 120. I need 2.5 power winkeye
cliffybabe
Powered by Nelly
Powered by Nelly
Thu Nov 23, 2006 5:06 pm
bmwe30mtech wrote: You were well into the three figure speeds mate....m40 wont go much over the indicated 120. I need 2.5 power winkeye
:lol:
liam012
Thu Nov 23, 2006 5:20 pm
a 318is motor with 3.91 (or 3.73 if you are yhat fuel cautious) diff will yield great economy.
michael24m
Thu Nov 23, 2006 9:03 pm
wow, lots of feedback, thanks!
actually my m20b20 doesn't have such a high fuel consumption, but i was thinking the m40b16 has even better fuel economy and being motronic and all.
anyways, my m20b20 runs pretty smooth no problems.
so you are saying it's not worth the mod, even if mine is a LE-Jetronic engine?
liam012
Thu Nov 23, 2006 9:10 pm
what does your 2 litre give?
29mpg?
a 318is should give 36 maybe more
michael24m
Thu Nov 23, 2006 9:31 pm
well, i can't get my hands on an 318is engine :D
so if not, i'll sell the m40 lump, it's in good condition.
yes the 2 litre is making 23 mpg consumption wich i think it's pretty good for a 2.0 litre engine or not?:D
it's like 7.5-8.5 in litres per 100km
oh sorry i got the conversion all wrong...where i am from they do it litres per 100km
so it's like 34-35 mpg on the 2 litre sorry :o:
Thu Nov 23, 2006 9:43 pm
michael24m wrote:i'm going to do this swap for the better economy of city travel
LPG your existing engine.
320Touring
Thu Nov 23, 2006 9:45 pm
amen, or get a buspass, and use the car for fun stuff!
michael24m
Thu Nov 23, 2006 9:46 pm
yes, the LPG way.
let me guess if i get this right. it will have the same mpg, but with half the cost of the petrol? or will it have a slightly fewer mpg?
how about the power when running on LPG?
thanks!
Thu Nov 23, 2006 10:53 pm
LPG contains 20% less energy per litre than petrol (but the same by weight), so other things being equal, fuel consumption will rise 20%.
In practice you may get better than this, as the original fuel system may be past its best, and there is no excess fueling while the engine is warming up with LPG.
On the power side: A slight, but not noticeable, reduction in power if you use a single point venturi (cheap) system, or no reduction at all if you use a vapour injection (expensive) system.
michael24m
Sat Nov 25, 2006 9:12 pm
thank you for your advice!
i'm taking the LPG way into consideration. this seems like the best solution for my problem :wink:
