prop: hybrid 535i/E30 one or a standard E30 M3 one
exhaust: hybrid 325i/m30 one or a E30 M3 one. the M30 exhaust is larger than the 325i one but the M3 is the right bore.
engine mounts: home made custom ones or buy them from several places (i got mine from e30.de)
radiator: easiest is the E28 535i one (with E28 bottom hose) but if the engine is far enough back you'll get away with a E34 535i one
the rest should be adaptable from the E34 if you have a full donor to hand. keep the E34 engine loom/ecu etc and use that complete.
it's a bit more than an easy few days but if you have the cars there and most of the parts, the heavy work will take a couple of days, after that it's mainly plumbing and exhaust work etc.
a week off with good weather should get it running (assume no waiting for parts)
all good fun though! good luck!
