M50 Engine Questions
m-dtech
Unapproved Trader caution
Post Thu Nov 16, 2006 7:28 pm
Would this work.....
M50B28 bottom end
M50B25 (non vanos head)
T3/4 Turbo
Megasquirt ECU
Happy days :)
Post Thu Nov 16, 2006 8:45 pm
Im about to use a 2.8 bottom end with a N/V 2.5 head
Will probably rebuild the crank and rods into a 2.5 N/V block though as ive heard the liners move about in the 2.8 and cause the head gasket to fail.
N/V inlet cam has 1mm higher lobes, the valves protrude past the head face so should mean higher compression, also has double valve springs winkeye
Anyone know if there are any oversize pistons I could use?
May aswell while its all in bits eh :)
