s50 conversion with getrag 260 ?
infusion
Post Thu Oct 26, 2006 10:15 pm
I have been researching and have been told that you can use your standard e30 325i box with the s50 conversion
Is this true ? or is it only for the US S50 ?
I will be paying for my engine today........ but it will be no good if i cnat use my current box
thanks
jmc330i
Post Thu Oct 26, 2006 10:33 pm
US S50 has the same bolt pattern as the Euro S50 and M50 engines.
jmc330i wrote: The E30 325i box will bolt up to the S50, but is rotated slightly in one direction. This means the gearshift will be off centre - the guys in the US dont seem to have a problem with this and I think some have managed to re-centre the gearshift (Im not sure how).
buster wrote:
infusion wrote:what needs to be done to fit the e30 box to the s50......... looks like i might be going down that route??
Im not sure as nobody here has done it that way.
If its the same for the m50 engine then a few have done that.
Probably is the same as the M50 engine but I'd imagine you'd have to use the flywheel/clutch M50 boys do... Will it take the torque? You hear of 2.7 boys munching gearboxes too.
James
'91 325i Sport
'93 318i touring 16v
infusion
Post Thu Oct 26, 2006 10:35 pm
ok was just making sure!
I am aware of the 10deg twist on it, that is ok
ok well if it can be done................. i will pay for the engine today
ta lads
jmc330i
Post Thu Oct 26, 2006 10:47 pm
The problem you have on this site, is most people will have used the gearbox that came with the engine or at least the correct box for the engine.
How come you want to use the E30 box? E36 or even E34 gearboxes cant be too hard to find.
James
'91 325i Sport
infusion
Post Thu Oct 26, 2006 10:56 pm
well.... i dont have the zf box and i dont really know where to get the propshaft shortened and re balanced etc.
At least if i use the 260 with the same propshaft, flywheel etc i dont have to spend load more on parts.
These parts are hard to get and very expenisve in Australia, so im trying to use what ive got
you know what i mean?
jmc330i
Post Thu Oct 26, 2006 11:01 pm
Ahh, makes sense now :cool:
Let us know how you get on. As was said on your other thread, nobody has used the E30 box on an S50 on this site, so it will be a learning curve 8)
James
'91 325i Sport
infusion
Post Thu Oct 26, 2006 11:05 pm
great, im a pioneer! heheh just what i wanted.................
oh well i guess i may find out the hard way then
thanks heaps
