Those with an M30 swap, do you still have A/C?
JoeyLink
Post Sat Oct 21, 2006 6:23 pm
I'm considering an M30 swap because my rear main seal just took a shit and I don't feel like doing it and/or spending the money to have it done. I want to know if those of you who swapped in an M30B35 were able to keep your A/C.
Andy335Touring
Post Sat Oct 21, 2006 8:12 pm
Sorry, i don't know of any 335's with A/C
eko
Old timer
Post Sat Oct 21, 2006 8:15 pm
ditch it anyway,power drain!
Welcome to the zone too :)
JoeyLink
Post Sat Oct 21, 2006 9:16 pm
Thanks for the welcome :)
That just might make me reconsider this swap :(
gareth
Post Sun Oct 22, 2006 3:21 pm
i suspect it can be done but space will be tight. the engine will have to be right back to clear the pas pump at the front. the hoses will pass through the space for the airbox, there will be less room for everything really!
devinwwu
Post Sun Oct 22, 2006 4:34 pm
it would have fit no problems in my car but i have a feeling that this is cause i have a lhd car and most of you are rhd..
of course i didn't keep it hahaha
you know how heavy those damn compressors are??
e30cossie
Post Sun Oct 22, 2006 4:43 pm
If the air con pipes are in the way get custom pipes made i dont think it would be that big a problem.
gareth
Post Sun Oct 22, 2006 6:19 pm
the pipes should be ok, easier to ensure clearance through using a smaller airbox tbh.
oze30
Post Sat Aug 25, 2007 10:37 pm
I have AC with my 3.5. no real issues. Still clears the airbox and no issues with cooling (the AC fan cools my engine well enough.) It IS tight near the rad, but i'm using an e28 535 rad, so it sits heaps lower.
