IM BACK !!!
blingsta
- Boost Junkie
Im back and happy again.. cars been up and running with new engine now for couple of days, but i thought, hey lets not get too excited, Anyway, after a night out with Ant last night mapping, car seems excellento and once again put a smile on my face!! still running 7psi but just need bigger injectors to complete the set up.. im gonna wait a few months before i spend any more money on her though, these past 2months have bled my dry and i cant afford anything else, need to make sure everthing is sweet for a while before any more goes in.. so thats my story so far peeps, all these problems caused by my old blocks head bolt thread being stripped ????
e30_Turbo
- Boost Junkie
dazleeds
- old skool raver
excellent new s fella
just gotta hope i can sort that thread out now
www.oldskoolfantasy.co.uk
blingsta
- Boost Junkie
cheers guys.. loadsa saving to do.. but i will enjoy it as it is at the moment.. new year= new prospects
mattG
glad to its on boost again erol
- at least you've got a turbo
Ant
- Retired Team Member
Wohooooo, the bitch is back
how was the consumption on the way back dude ? should be sweeeeeet ( better than stock I'd say )
Matt, its Erel, but 10/10, oh, I have a sump for you too.
signed: "the geek"
signed: "the geek"
Email FTW
blingsta
- Boost Junkie
Ant, consumption isnt bad mate, but you know me, on boost all times, so it does drink a bit !!!! but hey, sod it, it turns heads, and i am a bit of a show off.
.. Anyway, after all the engine troubles ive had, all the paint on rocker cover and inlet manifold has been scratched and scuffed, so i will be treating them to a nice coat of paint soon... Oh and Matt, once Ant finishes your car mate, im sure you'll be well happy
gcorky
- Boost Junkie
blingsta
- Boost Junkie
OOOOhh yes, im selling that if anyone on here is interested?? cost me Ԛ£115 selling for Ԛ£75, also selling the decomp plate for Ԛ£100 (3mm)
stonesie
1 word mate..... timesert...... far far better than helicoilsdazleeds wrote:excellent new s fella![]()
dazleeds
- old skool raver
stonesiestonesie wrote:1 word mate..... timesert...... far far better than helicoilsdazleeds wrote:excellent new s fella![]()
tell me more mate
sounds interesting
Iain temples building the engine for me and it will be having some machine work done too the block and the head
ps youll get more than banned if you buy a mk1 micra
stonesie
They are a iron thread insert rather than just a coil, you have to drill out and tap the hole then thread the timesert in with some threadlock, the tool that you thread them in with actually flares the lower end too to lock it in place.
Make sure you get the long ones to spread the load, when i built engines for a living we used these on a couple of M52 alloy blocks and never had a problem.
Found them....
http://www.wurth.co.uk/cat.php?section= ... =time-sert
Found them....
dazleeds
- old skool raver
nice one fellastonesie wrote:They are a iron thread insert rather than just a coil, you have to drill out and tap the hole then thread the timesert in with some threadlock, the tool that you thread them in with actually flares the lower end too to lock it in place.
Found them....
will show that to Iain
dnt suppose you fancy tackeling the thread?? as youve done it before and all
will pay for your time etc and were not far apart ??
wnt have the block here till after the pod meet 5th nov
stonesie
i havent got all the gear to do it and the block top would probably need skimming afterwards, Iain will be able to do that.
dazleeds
- old skool raver
no worries matestonesie wrote:i havent got all the gear to do it and the block top would probably need skimming afterwards, Iain will be able to do that.
may shout you for some advice if thats ok fella
