e30 with s50 (one day)
simys
Post Fri Oct 13, 2006 10:04 pm
iv got a e30 and im trying to put a s50 e36 m3 engine into it
iv changed the sump and chaged the servo. but what engine mounts do i use
is it the e28 m5 rubber mounts and use the e36 metal arms do i have to cut the plenham chamber if this is correct
thanks
jmc330i
Post Fri Oct 13, 2006 10:19 pm
simys wrote: is it the e28 m5 rubber mounts and use the e36 metal arms
Yes.
Depends on if you want to keep the brake servo. If you do, then the plenum needs cutting.
James
'91 325i Sport
'93 318i touring 16v
old_skool
Post Sat Oct 14, 2006 8:33 pm
:wave:
Get it in there and don't forget to write all about it :lol:
