M50 with ZF box?
Sooty
Post Thu Sep 28, 2006 5:27 pm
Is anyone else using the larger case ZF box with their M50 install? :?:
I'm trying to find the right combination of shifting arm carrier & selector rod to use.
Anyone happen to know, to save me hours & hours of searching?
Iain S
jmc330i
Post Fri Sep 29, 2006 12:03 am
Im pretty sure I used E30 stuff, with the E36 M3 lever - my box is the ZF 5spd box.
I had both the E36 and E30 stuff, so I just mixed and matched until the lever was in the centre of the hole in the tunnel, but Im 90% sure it was the E30 carrier and selector rod.
James
'91 325i Sport
'93 318i touring 16v
eko
Old timer
Post Fri Sep 29, 2006 12:09 am
I used E36 parts with my M50 box!
Post Fri Sep 29, 2006 8:54 am
Im not using that box but I know a man who has
E36 325 arm and selector rod,
100% without a doubt 8)
jmc330i
Post Fri Sep 29, 2006 9:54 am
Hmm, thats interesting. Im sure the only E36 part I used was the lever.
I will check over the weekend what parts I have left over and whilst the car is up on ramps will try and see what bits are fitted.
James
'91 325i Sport
Sooty
Post Fri Sep 29, 2006 5:12 pm
I got hold of an E36 325 arm, but it puts the gearlever too far to the right (turns out it's a coupe one which is different to the saloon one). Doh !!! :o:
A std E30 arm brings the lever central but too far to the rear.
With both arms, the gearlever has that much travel, it's hitting the front & rear of the console.
I think the next step is to buy a 328i arm & see what thats like.
Might as well get the Z3 1.9 lever while I'm there.
It's only money....................... :cry:
