12.9 M20B25 head bolts *** group buy ***
e30_Turbo
- Boost Junkie
As there are more of us around now I though it would be a good idea to get a group by sorted.
The bolts are 12.9 grade and the usual socket cap end type.
I have them fitted to mine and torqued to 80ftlb's which is nearly three times the stock pressure, they are also non strecth so are reusable.
14 bolts work out at Ԛ£4.50 each or Ԛ£63.
More people = less cost.
List:
1. Ant
2. Ant
3. Ant
4.
5.
6.
7.
8.
9.
10.
11.
I'm also gonna contact some head gasket suppliers as there may be a need for some of these too.
List:
1. Ant
2. Ant
3. Ant
4.
5.
6.
7.
8.
9.
10.
11.
fowler
- Boost Junkie
List:
1. Ant
2. Ant
3. Ant
4. ben aka fowler
5.
6.
7.
8.
9.
10.
11.
EX A-Tech Workshop bitch !!!
gone but not forgotten
e30bb
I'll have set, please.
Is it hex or torx?
and do u take paypal?
Is it hex or torx?
e30_Turbo
- Boost Junkie
Ben, yours are on their way to your secret e30 high power turbo testing facility in Kent, the technician will, at your request, insert them in your holes and tightening as neededfowler wrote: List:
1. Ant
2. Ant
3. Ant
4. ben aka fowler
5.
6.
7.
8.
9.
10.
11.
Good luck dude! I'll be down soon to take a peek
oldroydsr4
I'll have a set to please, just send me a pm when payment is required.
oldroydsr4
Fozzy, looking at a H1c. Is it recommended?
Dave
Dave
e30_Turbo
- Boost Junkie
Thats what I haveoldroydsr4 wrote:Fozzy, looking at a H1c. Is it recommended?
Dave
Just make sure you check the wheel sizes, housing size also, there are some monsters out there, you really want HX35 size,
Post up what you find and we'll help as much as poss.
Mark.
oldroydsr4
Its currently on ebay, the photo is taken wit a t3 (i didn't think the Holset was that big
), that will barely fit in the engine bay.
Item number: 270033102329
Ant
- Retired Team Member
18cm/3 housing on that unit, I have asked the seller for the assy number.
Email FTW
Gunni
shouldnԚ´t you put a final date on this,
I might be down for a set
e30_Turbo
- Boost Junkie
oldroydsr4
Cheers for your help, boys
dave
dave
iKst
I was reading FAQ on e30tech and i found this:
Those are 30 usd + shipping from US (cant be too bad). Why do these from group buy cost almost 3x more ? Are they much better, what is the difference etc.Q: What head bolts or head studs should i use?
A: Metric Blue - grade 12.9 head bolts http://www.mcmaster.com/
Part Number 91303A306 $10.56 per Pack of 5. you will need 3 packs of 5.
also, use the washers from your old head bolts.
Material
Class 12.9 Blue-Coated Alloy Steel
Head Style
Standard
Drive Style
Hex Socket
System of Measurement
Metric
Thread Size
M10
Length
150 mm
Hex Key Size
8 mm
Thread Style
Standard Right Handed
Thread Length
Partially Threaded
