hey all,
got my car running but the bleed valve on the thermostat has been round off, how can you bleed te cooling system with out using it??
does the temp gauge work with the M30 temp sensor??
how do i get my electric windows to work now that the engines in and working? they work if i unplug the engine from the blody.
Cheers for any help.
how do you change your name on here?
Gall
M30 Conversion Help.
gall
Andy335Touring
You might be able to bleed it by taking one of the temp sensors out but i'm not sure ? Will the bolt not come out with some Mole grips ?
Do you have constant hot air coming out of the heater ?
A new 'stat housing(11 53 1 268 650) is 15-20 quid and the blead bolt (11 53 1 275 881) is less than a quid
You need an M20 temp sender.
Have you got two big and two small wires going to your starter ?
Name change, try PMing a mod ?
