turbo problems!! cars dead!!
blingsta
- Boost Junkie
Hello again boost junkies.. BIG problem this morning, ive driven all the way home from work and the car decided to cut out infront of my house??? no pre warning of any kind, engine just turns but doesnt start? first thing i checked was that im getting fuel, but as my car is m/s and turbo'ed which i dont know much about, im drawn to a blank????? help is desperate!!!!
... what do i check for? has this happened to anyone else that has gone turbo?
Turbo-Brown
- Boost Junkie
Have a spark plug out and see if it's covered in soot.
A flooded engine would be my guess.
Turbo's not relevant to it starting - turbo's not spinning at start up - unless, of course, the cylinders are full of bits of turbo.
Check sparks, fuel, compression, timing in that order - same as any non starting engine.
brightyboy
Ant
- Retired Team Member
Hmm just called, guess you're on nights ?
Anyways, when you cycle the igintion on/off you should hera the fuel pump prime for two seconds ( whirring noise)
Assuming that happens its not the fuel pump or relay.
plug in the laptop, power it up , then power the ignition again dude, the live data display should help with diagnosing the problem, assuming all the displays are in the normal range and none are RED, then crank the engine over and check the rpms display agrees with the tach on the car.
the engine MAP sensor ( kpa display) should show 98kpa ish @ rest, lower on cranking , if the Kpa is unchanged then the Map sensor feed line may have come adrift.
Lemme know OK
Lemme know OK
Email FTW
blingsta
- Boost Junkie
thanx for all your help guys
stuartgallafant
blingsta
- Boost Junkie
Yep, big smile on my face again, thanx to that man Ant!!! after loads of checks and tests, it was believe it or not down to a slipped thru the net dodgy m/s ecu... well only one wire which controls the spark dropped off its solder?? but yeah, all sorted now.
Ant
Easy when you know how
Email FTW
Turbo-Brown
- Boost Junkie
Hmmmm, was it a simple dry joint, or had the solder melted perhaps pointing to something overheating?
Ant
thought the same Alex, the wire itself had come adrift but it was the signal to the FET, not the power handling side, weird for sure, Back up and running the FET's run cool enough to touch, infact the inj drivers run warmer than the coil ones, all are barely warmer than ambient when compared to bare alloy.
If the FET had failed, the damage would have been obvious, almost certainly would have melted. strange, annoyng but not the end of the world
Email FTW
Turbo-Brown
- Boost Junkie
How bizarre!
Can't beat the good ol' electrical gremlins tugging at wires and the like, good that it's sorted now!
blingsta
- Boost Junkie
ive just got home from work... car didnt cut out today!
end of problem! Oh, and also beat my mate honda civic type R in a race
Ant
how was she now you have the full rev range dude ?
the fuel cut seem better suited to in town driving on the revised settings ?
I lifted the boost cut limit a little yesteday, shoul not be able to trigger it now.
another addict
Email FTW
blingsta
- Boost Junkie
alot better Ant, thanx, i did accidentally go full throttle at one stage though, then i remembered that i havent got a map setting for that.. hope it doesnt do damage? i checked the temp of the ecu again and its still cold mate, so job well done! cant wait to turn up psi dude, just about to put bleed valve on now!
