i did a quick search on turbocharging M10 but i didnt find much. So i hope all you guys with turbo M10 will share your knowledge in this thread.
Whats actualy needed to turbocharge an M10. My goal is reliable, 300hp engine that will be used in my road car that i also use for drifting. I would also like to avoid parts from M cars because they are very hard to get here and expensive.
Engine block.
Are M10 blocks all the same. I have a few 1600ccm, 75hp engines at home (carb, not sold in E30 in UK market but i think they are the same as in E21). Is this a good base for a project.
Cylinder head.
How good is stock head ? My goal is around 300hp. What head is best to use for this kind of power.
Pistons.
I read somewhere that you can use forged pistons for VW bug. Is this true. If so i think its a good option, because they are cheap. If not what pistons are good. Stock pistons probably wont be strong enough for 300hp and fairly high boost.
Crankshaft and conrods.
Whats a good option. I think that E21 320 (4 cyl.) had forged crankshaft. What conrods can i use for this kind of power ?
Intake.
Stock intake is probably too small. What TB can i stick to M10 intake manifold. I have a few M50B25 TBs at home, can i make an adapter to fit that or something ?
Exhaust manifold.
Can i use some stock bmw part from a some turbodiesel or something ? If not i think i can make a "log" exhaust manifold. Doesnt look too complicated and is probably cheap. How much power can these manifolds take on 4 cyl. engine ?
Turbo.
Whats the cheapest and most common turbo that can handle 300hp ? Is there enough place for a turbo on LHD cars ?
Fueling.
Can i use Greddy eManage ? I can get one cheap from a friend. If not, what do i use. I will probably need something not too expensive and not to complicated.
Fuel pump wont be a problem, ill probably order a Walbro 255l/h from ebay, but what about injectors. Is any stock bmw item big enough for 300hp on 4 cyl. ?
Gearbox.
Will a gearbox from E36 325 fit on M10 ? I didnt try but it looks like it should go on and IIRC they are good for 300+ hp. If not, what do i use.
I hope this is not too long
