Help please - need advice re engine swaps
SPADGE
Post Tue Aug 15, 2006 8:52 pm
Hi all
I was about to embark on an M30 conversion into one of my tourings but before i start would like your input please.
I already have a 535 E34 with a lovely engine and manual box as a donor but is that the best option as regards power/torque gains balanced with price and ease of the conversion itself over an above a 325 engine?
Secondly i have 2 tourings one of which i would like to use. One is a 325 SE Auto which i would convert to manual at the same time and the other is a very late L plate manual 318i which has a slightly better body than the 325. My dilema is basicly which one would be the easiest/cheapest to do as i am not sure which parts of the 2 cars mentioned above are shared?
Any input appreciated fella's
Cheers Spadge...
ed325i
Post Tue Aug 15, 2006 9:09 pm
I would convert the 325 auto to a manual and put the m30 in the 318. like you say do a search for info on the conversion.
SPADGE
Post Tue Aug 15, 2006 9:13 pm
ed325i wrote:I would convert the 325 auto to a manual and put the m30 in the 318.
Forgot to mention i also have another touring which is a 325 manual :mad:
Colour is another issue which isn't helping as the 318 is silver and the 325 is some sort of dark blue metalic and looks lovely :?
ed325i
Post Tue Aug 15, 2006 9:16 pm
You only have 3 :mad: use the best one for the m30 doesnt matter if its a 325 or 318
SPADGE
Post Tue Aug 15, 2006 9:33 pm
ed325i wrote:You only have 3 :mad: use the best one for the m30 doesnt matter if its a 325 or 318
Cheers thats was my feeling to use the best body/overall car for the conversion which is without doubt the L plater!
Does a 318 use pretty much the same running gear as the 325 ie Prop etc...and i don't suppose the 318 manual box will fit the 325 by any chance??
Cheers Spadge...
Gunni
Post Tue Aug 15, 2006 9:40 pm
depends on what gearbox but you might be able to usa a auto shaft with your m30 trans,
I used a 320i prop with a m10 trans ;)
Gunni
@ 2012 VEMS group buy !!
fuzzy
He who sleeps with "Gingers"
Post Tue Aug 15, 2006 9:44 pm
it would be best using the 325 as that would have the 51mm struts,rear disc brakes and most likely an lsd already fitted
SPADGE
Post Tue Aug 15, 2006 9:52 pm
fuzzy wrote:it would be best using the 325 as that would have the 51mm struts,rear disc brakes and most likely an lsd already fitted
Hi mate
The 318 also has rear disc brakes as it is a Lux or because its a late one i don't know lol :D
Know a lot more about whats under your bonnet than this beemer stuff :wink:
ed325i
Post Tue Aug 15, 2006 9:55 pm
rear disc brakes
A 318 touring will have rear discs ?
You can use a e30 m3 prop for the m30 conversion.
Do a search on here and have a look on www.e30.de
ed325i
Post Tue Aug 15, 2006 9:57 pm
You beat me to it :D
fuzzy
i didnt know 318's came with rear discs,i thought it was just 320 and 325 tourers.are you more a cossie man then? winkeye
SPADGE
Post Tue Aug 15, 2006 10:18 pm
fuzzy wrote:i didnt know 318's came with rear discs,i thought it was just 320 and 325 tourers.are you more a cossie man then? winkeye
Lol i'm surprised you havn't heard my name in the cossie world mate as i was doing them for years. Been there and done it with the Cosworths though so decided to have a play with an E30 or two :) Problem is its a bit like learning another language and its weird being a rookie when i have over 15k posts on Passionford lol!
jmc330i
Post Wed Aug 16, 2006 2:07 pm
All tourings have rear discs. The difference between the 4pot and 6pot touring suspension is the front springs, the struts are the same.
James
'91 325i Sport
'93 318i touring 16v
Andy335Touring
Post Wed Aug 16, 2006 10:04 pm
Only the 325 Touring came with M-tech suspension so the front struts are the bigger diameter ones(51mm ??).
Not sure about the ARB's though ?
Not that it matters because you will probobly want to change it for some after market sporty stuff any way for a 335.
I ran my 335 to start off with on the M-tech suspension, it wasn't bad but i wanted some thing stiffer with less roll.
gareth
Post Fri Aug 18, 2006 5:36 pm
what are you running now andy?
Andy335Touring
Post Fri Aug 18, 2006 8:39 pm
gareth wrote:what are you running now andy?
Spax adjustable dampers and springs, i ordered Spax M3 springs because i thought they would be stiffer but the rear was to low so i used Spax saloon/Touring rear springs with the front Spax M3 springs.
It's a tad(1/2 inch) to low at the front but it rides well and looks good.
SPADGE
Post Sun Aug 20, 2006 1:19 am
Cheers for the replies fella's!
I will indeed be buying aftermarket suspension and so the size of what is on there now is of no real consequence.
Can somebody give me a number for the place that sells the engine brackets for mounting the m30 into an e30 and give me an idea as to what they cost?
Cheers Spadge....
ed325i
Post Sun Aug 20, 2006 8:15 am
Go to www.300mm.de and go to the engine mount section.
SPADGE
Post Sun Aug 20, 2006 10:39 am
ed325i wrote:Go to www.300mm.de and go to the engine mount section.
How its in German :mad:
Post Sun Aug 20, 2006 1:09 pm
all tourings came with m-tech sus and all round discs
ed325i
Post Sun Aug 20, 2006 8:17 pm
E Mail Tino his e mail is 300mm@gmx.de he speaks english he will sort you out.
Andy335Touring
Post Sun Aug 20, 2006 8:38 pm
Jhonno wrote:all tourings came with m-tech sus
Only the 2.5, ask Argos
Post Sun Aug 20, 2006 8:48 pm
Brianmoore reckons all im sure of it..
ivqii
Post Sun Aug 20, 2006 9:26 pm
Our resident engine swop expert stevetigger will answer all your q's - even the ones you havnt asked yet - when he starts posting again
gareth
Post Tue Aug 22, 2006 8:51 pm
the M-tech stuff is imho too soft for real performance and this is aggrevated by any heavier engines fitted. though in my case i started with a heavy tourer then dropped in the M30 so it's a worst-case jobbie
