as title ,anyone experience with this type:
BRAND NEW IN THE BOX 40 MM WASTEGATE,
WITH ADJUSTABLE BOOST CONTROLLED SPRING
10 Psi TO 18 PsI
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %26fvi%3D1
no adjustment externally???reseller wasnt helpfull-i presume part strip to adjust?????
got a bleeder type valve to increase also.
wastegate adjustment?
gcorky
- Boost Junkie
Toby_Unna
- Boost Junkie
I've got the 50mm version
seems to work ok. there is no ext adjustment, to alter boost take cap off (4 hex head bolts) and replace spring or shim current spring. 10 mins work.
