Just acquired a E30/M50 and before I go pouring gallons of oil into it, I thought I'd check that the dipstick is reading correctly!
Anyone know the part number for the dipstick you need for a M50 conversion?
Andy
M50 conversion , unusal question
jaistanley
Good question... You mean becuase the engine is at a different angle of tilt, or because you are using the 5 series sump?
I don't know for sure yet but I beleive you use the 5 series 525 dipstick.
Jai
Jai
Engine will be at the correct angle if you use the E36 mounting arms and dont use any spacers on the mounts (about 20°)
If you use an E34 sump then you will need an E34 dipstick
TW166Y
looks like your gonna come in handy dan....DanThe wrote:Engine will be at the correct angle if you use the E36 mounting arms and dont use any spacers on the mounts (about 20°)
Im deffo thinking about this conversion now
Saying goodbye to 4-pot wrongness
