325... which path to take
will_c
Post Mon Jul 24, 2006 10:21 pm
Hi there, Im currently umming and arghing about selling up my 200sx S14a and getting a E30 325i. Now a standard 325 is no where near fast enough for my boost adiction so i would be buying one as a project. Due to the mileage found on these engines a rebuild would be called for and it would make sence to build a nice low compression forged engine to accept a turbocharger. I would be looking for around 350 - 400 bhp with a Garret GT ball bearing turbo and a stand alone engine management system. The only thing i dont really know about is the bottom ends found in these cars. Which is the best one to turbocharge, obviusly i ll be going for low compression forged pistons and rods, and a thicker head gasket but are there any issues i should consider on the 325i engine regarding my plans?
Are there any bmw tuning companys/engine builders i could discus this with?
Turbo-Brown
Boost Junkie
Post Mon Jul 24, 2006 10:30 pm
Go for the low compression later engine and you shouldn't have any probs getting to your target 350bhp :)
If it goes pop, buy another one for a couple of hundred quid and off you go again!
Little bit bizarre that you'd elect to use low compression pistions AND a thicker head gasket though, one's the correct way to lower compression, the other's not, and if you're using one, why bother at all with the other?
will_c
Post Mon Jul 24, 2006 10:33 pm
well i want a fully rebuilt and forged engine so does it really matter which engine i get?
i.e, are there any issues with taking an engine from an F reg 325 and sticking forgies in and a thicker head gasket? obviusly the compression ratio will all have to be calculated and the block will need machining etc.
Turbo-Brown
Boost Junkie
Post Mon Jul 24, 2006 10:34 pm
Guess not in that case, but why on earth would the block need machining?!
And why would you want to weaken your strong new engine with a thick head gasket?!
will_c
Post Mon Jul 24, 2006 10:47 pm
you ll have to forgive me, i dont really know anything about these engines yet. The block will need the general machining work for the rebuild i.e honing the cylinders or boring them out if i went for larger capacity etc. Thicker head gasket to aid the lowering of the compression ratio but if its low enough already? then it wouldnt be needed.
How much can you safely increase the capacity?
what sort of compression ratio should i be aiming for?
maxfield
Post Mon Jul 24, 2006 10:51 pm
I don't think you can bore it out anymore. but you can stroke it to 2.7 or 2.8.
The later engines are only a compression ration of 8:5 or something cloe to that. Which is low enough to run high boost.
Turbo-Brown
Boost Junkie
Post Mon Jul 24, 2006 10:55 pm
I know Player6 has a 2.8 which is using the crank from some E36 engine or other and presumably an overbore.
You could probably start off with a 2.7 (there seem to be various ways of going about that one).
The stock compression on the later engines is less than 9:1 anyway (8.8:1 springs to mind but someone will be able to say yay or nay to that one) so they can handle pretty large doses of boost :)
I'd say if you're going to the trouble of getting forgies, get them made up so that you don't need the thick HG. It's such a bodgetastic way of compression lowering!
Sounds like you've got some cash to put into this engine if you're talking about forged pistons and steel rods, would be a shame to build in a weak link :(
will_c
really? hmm thats pretty blooming cool then!
so i could just get a later engine, stick some forged pistons in and bolt on a turbo!
mmm
maxfield
Post Mon Jul 24, 2006 10:58 pm
I think ant said 8:8:1 at aces iirc
maxfield
Post Mon Jul 24, 2006 10:59 pm
TBH you could just stick on a turbo without forged pistons and run to a certain amount of boost
will_c
well what it is is im going to sell my 200sx and buy a car for around 3k with a mint shell and a suitable suspension etc, that leaves me with 3-4 grand to play with the engine. £1000 of that will be the turbo and id want a rebuild gearbox aswell.
How much power and torque can a standard box take?
Andy335Touring
Post Mon Jul 24, 2006 11:52 pm
Like Alex said, if you are going to build an engine with low comp pistons you don't need or want a thick gasket because this increases your squish height which isn't ideal, have a read of this and good luck with your project as it sounds cool 8)
This was posted for me on another forum
This is where this info was taken from, it might be a good referance book to have for your project ?
Lee_Coupe
BEWARE Zone Thief
Post Tue Jul 25, 2006 12:05 am
Will_C...
Dont suppose you used to have a Rover Turbo in black with 18/19's? used to be on rovertech, I used to own a coupe! (Lee_Coupe)
You've joined the bimmer world aswell I see :D
will_c
Post Tue Jul 25, 2006 12:13 am
I did mate!
http://img175.echo.cx/img175/7167/1111157img9aq.jpg
i broke it in the end and got about 9k for it in bits! Some fella in spain bought the engine and box for about double their value lol
bought a 200sx but my new job means too much traveling to have a car like that!
need a crappy van or somthing and then i ll have £Â£Ã‚£ for project bmw :D
Lee_Coupe
BEWARE Zone Thief
Post Tue Jul 25, 2006 12:34 am
I remember mate, That thing was fcuking lovely!
Sadly there not RWD tho lol
Sold mine for a nice profit to pay off some depts and buy my touring.
Good luck with the new project buddy, going by the standard of your rover Im sure the BM will be a lovely car! :cool:
Boots_Walker
Post Tue Jul 25, 2006 12:31 pm
given your target of 350-400hp i would be inclined to start with a 8.8:1 2.5 and leave the bottom end stock, m20's are tough and i believe that those power levels are safe provided the car is setup and tuned properly.
thats my opinion :)
Post Tue Jul 25, 2006 12:44 pm
I don't know much about your existing car, but is if the car ain't too smart but the engine is healthy and not suffering with the usual main & big end knock, then why not transplant it into the E30?
When I have the cash & facilities, I'm gonna do a jap transplant into an E30, using the 7m GTE lump out of a UK MK3 Supra, or if I am lucky enough, the 1-jz out of a TT Soarer/ MK3 Supra import.
Post Tue Jul 25, 2006 3:09 pm
if your gonna run custom pistons then you can dictate CR, could stroke it and bore it out slightly (i believe they will take a small increase in bore size
350-400bhp is achievable tho, maybe even on the standard bottom end if you do it properly 270bhp is the highest turbo'd figure i can remember from here on a standard bottom end
Turbo-Brown
Boost Junkie
Post Tue Jul 25, 2006 5:00 pm
270bhp is what I'm getting, and that's only on 7psi with the high CR engine.
Sure Ant and Fozzy are getting way more than that, think Fozzy's running 20psi or something crazy like that on a standard low CR engine! :D
e30_Turbo
Boost Junkie
Post Tue Jul 25, 2006 5:14 pm
I've peaked at 1.3bar but that was too much for the head bolts and it slammed no 1 and 6 HG clean into the water channels.
Next time it goes it'll go big time, then I'll buy another one and strap the bitch on again!! :twisted:
LOL @ £1k Garret tho....... you guys are all nuts :mad:
Post Tue Jul 25, 2006 5:37 pm
Turbo-Brown.. yours is the only one that been r/r so far tho..
Ant
Retired Team Member
Retired Team Member
Post Tue Jul 25, 2006 5:51 pm
wanna bet M8 :?:
Post Tue Jul 25, 2006 6:03 pm
lol
meant to say only one thats been r/r and figures shared that im aware of...
share the weath then dude..
WillG
Post Tue Jul 25, 2006 6:51 pm
maxfield wrote:I don't think you can bore it out anymore. but you can stroke it to 2.7 or 2.8.
you can bore it out to 85mm fine
Will C, if you want forged pistons (which you dont need) then contact JE and tell them was CR you want and fit a stock thickness MLS headgasket or get block o-ringed when you have it bored , fit new bottom end bearings, rods are fine as they are but if you go to 500hp swap to M50 rods.
Or you could just do new rings, bottom end bearings and get a .140" MLS gasket to low CR abit, or you can mill/lathe pistons abit aswell.
Dont need forged rods atall, might want to get a balance with forged pistons cos they abit lighter but people have fitted them and done ok without
d6dph
Post Tue Jul 25, 2006 7:51 pm
Jhonno wrote:lol
Hehe i know! well i was at one of the r/r runs. not sure if its been done again.
but my lips are sealed :wink:
will_c
Post Tue Jul 25, 2006 7:59 pm
Whats involved with increasing the stroke then?
Well i ve been thinking about some of the things im gonna want to do.
over bore, increased stroke, JE custom forged pistons, fully balenced bottom end, metal head gasket and an ARP head stud kit
will the standard head be ok to use for a while? i.e valve sizes, cam profiles etc?
WillG
Post Tue Jul 25, 2006 8:10 pm
I wouldnt bother stroking it if you turboing its more hassle then its worth,
Rest of its fine, could throw a custom cam in there aswell for £200 but its not needed.
Whats your budget and what engine management and exhaust manifold are you going to use. I would seriously consider just rebuilding bottom end stock, put a thicker MLS in, Get head welded and a custom cam and put a holset on and your gona save alot of money and get same or better result then what you just mentioned result if your on any sort of budget that is by far best value for money.
Some guy ran a stock bottom end but totaly rebuilt along with head which was welded, 372 PPF cam, oringed block, stock 8.8:1 compression and was using a autronic ECU and he made 600hp and that was reliable he went up track lots and never blew it up so the bottom end is safe for anything you want if its tuned right.
will_c
Post Tue Jul 25, 2006 8:17 pm
budget will be around 3 grand.
so you rekon a fully rebuilt bottom end will be fine for 400 bhp?
I ll be having a custom manifold and exhaust made up
not sure on management yet... stand alone system... i had a DTA for my rover but never got round to fitting it.
Ant
Retired Team Member
Retired Team Member
Post Tue Jul 25, 2006 8:30 pm
spend the £Â£ on getting the head welded, some uprated head bolts( metric blues or M30 type 12.9grade ) and give the bottom end some new shells and bolts, dont forget to add a new oil pump, or at least change the gears in the top , just to be doubly sure M8
the rest is well up to task at hand
What turbo you planned to use ??
What type of manifold have you gone for ?
external or internal wastegate??
What size downpipe ?
lots to think about m8 Check out Fozzymonsters posting for ideas on the pipework, the downpipe is the limiting factor as there's no clearance on the steering
use the DTA if you still have it :cool:
will_c
Post Tue Jul 25, 2006 8:55 pm
planning on using a Garret GT2871r with internal wastegate. Not sure on manifold yet... any ideas? was planning on a custom one.
What am i limited to with the down pipe issue?
Just like to say, what an awsum forum! really really good! Thanks!
Ant
Retired Team Member
Retired Team Member
Post Tue Jul 25, 2006 9:01 pm
dude, torque monster turbo(small), you after an all rounder or top end ?
My T3 in 60 trim boosts @2.2K , monster torque up to 5.2K but HP suffers up top
will_c
Post Tue Jul 25, 2006 9:09 pm
Well this car is going to be built for acceleration and will mainly be used on the track so i dont want a big laggy turbo.
GT2871r can flow 400 bhp and has minimal lag
e30_Turbo
Boost Junkie
Post Tue Jul 25, 2006 9:18 pm
will_c wrote:Well this car is going to be built for acceleration and will mainly be used on the track so i dont want a big laggy turbo.
The GT2871r is too small dude, it can flow 400bhp but not on a 2.5ltr engine.
atp turbo wrote: This turbo is great for small displacement engines up to 2.2L
I'd suggest something like a Garrett GT2876R (aka GT25/40R) but I'd rather say get a Holset :D
HTH, Mark.
will_c
Post Tue Jul 25, 2006 9:21 pm
ah yeh, im still in 2ltr 4 pot mode!
whats a Holset?
maxfield
Post Tue Jul 25, 2006 9:29 pm
