bigpimpin wrote:I did connect the violet/white wire to the diagnosic port as per ian's instructions so maybe that will do.
I'll try swapping the coils this week if I get a chance.
Hi Sandy,
I don't recall anything about adding a wire to the diagnostic socket.
I think you may mean running the white/violet wire from the diagnostics socket (pin 20 - already fitted) through the C101 connector (pin 17) to the EWS module.
Regarding the hesitation. Could be plugs, MAF, throttle pot or even an air leak. The throttle pot is a service item (every inspection 2), so may be worth a try, and the MAF is also cheap/easy (assuming you have a spare from the other engine).
buster wrote:Demlotcrew wrote:Best thing is to visit someone with a diagnostics machine and pay the £30 odd they might charge to find out what the problem/s are.
Andrew
only problem with that is unless you wire in the original m3 cluster i dont think it will work.I know Ian said he has a multiplug so that he can plug a set in for this reason.
You would be able to use the diagnostics, but without the cluster attached, you can't align the EWS if it ever needed replacing.
Cheers,
Ian.
