Aftermarket exaust woe
JAMZ
Post Mon Jun 26, 2006 8:10 pm
Sup guys,
Well Me and Jon_bmw got to work this weekend on fitting the Turbo setup on the Cabby, come across a problem which we spotted but havent drove it yet but ive been thinkig it will get a much bigger problem once we do..
i have a 3-piece exaust stainless on there now,thing is apart from the rear box having the normal fixing with the rubber mount there isnt any outher suport/fixing untill we get to the downpipe (internal wastegate) which obvioulsy connects to the exaust flange..
before it was fixed right to the manifold so it was semi sturdy..had a lil knocking now and then from the centre section hitting the underbody but now this will be a major problem..having that exaust swaying around connected to the turbo and manifold like that is not a good idea..things will losen up or break very quickly i feel..
I didnt take the standar exaust off or did i fir this one but i cant see any outher fixing points whatsoever anywhere!
what can i do? any advise?
e30_Turbo
Boost Junkie
Post Mon Jun 26, 2006 8:20 pm
There's a hanger off the gearbox, bolts on, there a few quid from the stealers.
Otherwise there is another by the tank or just weld on another hanger to the pipes in an appropriate place, pics would be handy too :D
HTH, Mark.
JAMZ
Post Mon Jun 26, 2006 8:29 pm
Cheers Mark..
Neither of us have had much time with exausts so i dont know any diferent..could of got piccies but its getting a bit dark now..
i know you can get a kit from the factors which includes rubber,bracket for the centre section etc but not sure if it includes the bit your talking about?
I know the centre section brackets corrode up nicley so prolly why it was removed but surprised to see the outher 'L piece' was removed too and its that what confused me... didnt know there removable :wink:
the zorst is obvioulsy straight twin pipes from the flange down to the centre section then straight again to the backbox..what do you suggest?
surport at gearbox or fueltank area? im thinking gearbox as its nearer to the turbo setup.. but there isnt a bracket on the exaust there to fix to so maybe its the centre section then that needs to be surported with a kit..will they stock the 'L' piece too do you think
e30_Turbo
Boost Junkie
Post Mon Jun 26, 2006 8:36 pm
I'm not 100% on cabs, so there may be a diff in setup, maybe someone with the knowledge will advise soon :D
As far as I can suggest I'd say support the exhaust itself so it hangs were it should be with being attached to the turbo, so support by the bulkhead or gearbox is best bet. Centre section would be great if you can get the right bits in which should be a rubber bush and another bracket, I'd go have a look at one at the factors and see if it's gonna fit.
Pics are a good idea too, million words and all that
Mark.
Post Mon Jun 26, 2006 8:49 pm
Look here mate,
http://www.realoem.com/bmw/showparts.do ... g=18&fg=10
I bought parts 12 through to 26 not so long ago for my 3 piece system when I made up the frontpipes for my M50 lump.
Cost about £8 for the job lot, may take a few days to come though, all depends on your dealers 8)
JAMZ
Post Mon Jun 26, 2006 9:16 pm
Cheers.
What part of the underbody is that attached to m8?
Post Mon Jun 26, 2006 9:36 pm
Bolts straight onto the underside of the gearbox 8)
JAMZ
Post Mon Jun 26, 2006 9:54 pm
Diamond.. :)
Btw,you know yer sig pix isnt working? only saying cuz i had the dreaded red cross box for weeks on another forum but my end it showed the sig..just a heads up! :)
Post Mon Jun 26, 2006 10:16 pm
The Sig? or the Avatar?
I know when I log in on a PC there is a red X in the avatar area, but I cant see it on this Mac so Ive never done anything about it
Any difference now? :?
JAMZ
Post Mon Jun 26, 2006 10:20 pm
You got no Avatar whatsoever and as for yer Sig you have a broken link symbol.. i.e yer address you used for yer sig isnt working or is wrong
http://img419.imageshack.us/img419/182/sig2nz.png << thats yer link so something is wrong somewhere as that isnt loading in my browser and its prolly not imageshack at fault.... have you dleted the piccie at image shack or maybe tyrped the addy in wrong?
Post Mon Jun 26, 2006 10:27 pm
Not done nothing to it :?
The machines at the 2 other address's I log on with both show my sig pic.
Well they did last time I looked
jmc330i
Post Mon Jun 26, 2006 10:34 pm
Just so you know, I can see both your sig and avatar.
James
'91 325i Sport
'93 318i touring 16v
Post Mon Jun 26, 2006 10:38 pm
jmc330i wrote:Just so you know, I can see both your sig and avatar.
I have an avatar? :o
:lol:
Cheers :wink:
oguz327
Captain Armco
Captain Armco
Post Tue Jun 27, 2006 1:10 am
I had a new gearbox exuast mounting bracket fitted on a ramp yesterday on my tech 1 (3 piece system) cos the centre/down pipe section was hitting the heat shied or somewhere around the gearbox area. This was after fitting a 6 branch the other week.
The old bracket was shot and this has sorted the problem out.
Was £18 inc vat at the stealers :?
