335i gearbox options
ollielsd
Post Sat Jun 24, 2006 2:00 pm
just a quickie, what's needed to convert an auto 535/335 to manual?
charlE30
Post Sat Jun 24, 2006 5:04 pm
If you are using the later E34 M30 engine you can use any 3lt/3.5lt from E28/E32/E34 maybe others but if you are using the older E28 engine you can't use the E34 box. You will also need a suitable manual flywheel and clutch, I'm using an E28 single mass flywheel & clutch on an E34 engine/box. You CAN use the auto loom with no problems but think you will need a manual ECU??
I now have a spare E34 dual mass flywheel :D
BMW F31 335d xdrive
ollielsd
Post Sat Jun 24, 2006 6:25 pm
thank you for the reply mate.
so a e28 (5)35i would need the relevant e28 manual bow and ecu?
ta
charlE30
Post Sat Jun 24, 2006 6:51 pm
ollielsd wrote:thank you for the reply mate.
ta
And an E34 sump/oil pump..
BMW F31 335d xdrive
gareth
Post Sat Jun 24, 2006 9:06 pm
charlE30 wrote:If you are using the later E34 M30 engine you can use any 3lt/3.5lt from E28/E32/E34 maybe others but if you are using the older E28 engine you can't use the E34 box. You will also need a suitable manual flywheel and clutch, I'm using an E28 single mass flywheel & clutch on an E34 engine/box. You CAN use the auto loom with no problems but think you will need a manual ECU??
i have the auto ECU and loom and TPS. it all works fine.
charlE30
Post Sat Jun 24, 2006 9:19 pm
gareth wrote:i have the auto ECU and loom and TPS. it all works fine.
Wasn't sure about the ECU, I knew I'd be wrong :?
BMW F31 335d xdrive
