m30 3.5 swap help pls
ollielsd
Post Mon Jun 12, 2006 6:59 pm
apart from obvious stuff like fabbing engine mounts and sorting exhaust, is most of it plug and play?
for instance can i retain the 325i rad? gearbox?
what about loom and ECU?
basically i wanna see a comprhensive list if bits needed/modified
cheers guys
and yes i know theres a million posts on the subject buut the info is scattered thru 896 pages!
ed325i
Post Mon Jun 12, 2006 8:27 pm
You will need the m30 gearbox, loom and ECU, the down pipes can be mated to the 325 exhaust. I would use the e28 535 rad with elec fan. you will need the M3 prop or get yours modded.
ED
ed325i
Post Mon Jun 12, 2006 8:33 pm
And I fitted a MK1 golf servo so I could move the engine over so there was more clearance between the exhaust mainfold and the steering linkage.
ED
gareth
Post Mon Jun 12, 2006 8:41 pm
i hate to have to say this but have a search. i have just done this conversion and there is a pretty comprehensive post here:
http://www.e30zone.co.uk/modules.php?na ... light=335i
it's a quite a read!
there's a lot more on there too from others who have just done the conversion.
good luck mate, it's WELL worth it!
