What size pipe for manifold?
koos
Post Tue May 30, 2006 7:05 pm
As above, i'm gonna make my turbo manifold and wanted to know if anyone has an idea of what size pipe i should use? It's gonna be a log design, easier to make i reckon. Will make a plate for the head. Any help would be huge!!!!
Turbo-Brown
Boost Junkie
Post Tue May 30, 2006 10:24 pm
I made mine from 1 1/4" tube if I recall correctly (incidentally the same diameter as BMW used for the E36 M3 Evo engine manifolds by pure coincidence), but mine are 3into1 designs.
WillG
Post Tue May 30, 2006 11:05 pm
yep 1 1/4 (32mm) is the right size any bigger wont get nots on any smaller you restricting
jmc330i
Post Wed May 31, 2006 1:44 pm
1 1/4" for the primary pipes surely??
The 'log' section would need to be bigger wouldnt it?
James
'91 325i Sport
'93 318i touring 16v
Turbo-Brown
Boost Junkie
Post Wed May 31, 2006 1:47 pm
Yes, primaries only at 1 1/4" bigger after that if it's gonna be a log style manifold :)
koos
Post Wed May 31, 2006 6:18 pm
So 32mm(sorry metric only) for the ones coming off the head and the same size for the log? Is that correct?
jmc330i
Post Wed May 31, 2006 7:11 pm
Yeah 32mm for the primary pipes off the head.
The log would need be to bigger, but I would only be guessing as to what size it needs to be - it could also depend on the choice of turbo???
You could ask Ant what the size/dimensions of the BBR manifold are.
James
'91 325i Sport
martybee58
Post Fri Jun 09, 2006 2:13 pm
If you need the flanges making for the head and the turbo I can laser cut them for you. I already have T3 flanges drawn so all i'd need is a exhaust manifold gasket and I can knock some out from mild steel up to 10mm thick. (as long as you are using a T3 that is.....)
PM me if you are interested.
Martin.
I'm dropping the hammer!!
e30_Turbo
Boost Junkie
Post Fri Jun 09, 2006 4:25 pm
Martin,
You aint got a inlet mani flange on file do you?
I have a spare inlet manifold if you need to borrow it?
Thanks, Mark.
P.s. my primaries are 1 1/4 inch IIRC
martybee58
Post Mon Jun 12, 2006 8:55 am
I dont Mark. But if you need one doing I can do it. I'll need the manifold though.
