It's alive and fully 'standalone' 8-) *** with short vid ***
e30_Turbo
Boost Junkie
Post Sun May 21, 2006 7:48 pm
After a few head scratching weeks of trying this, testing that, rewiring this etc etc it all came down to one wire..... pity it took me three weeks to find it :mad:
All sorted now and I enjoyed a short drive around the block using MS for fuel & sparks, first time for me and damn was it smooth :D
Now to figure out how the timing map should be and yet more tuning but the quest to max out my mp sensor is now back on and hopefully this time without spitting another HG out :twisted:
Next up exhaust, having a custom chrome 2.5inch straight through single box system added next week plus some welding a new part of the downpipe too.
Not sure what tail pipe to go for tho, they do do a 8inch single :eek:
d6dph
Post Sun May 21, 2006 8:05 pm
Good work fella. Will have to pop over to see this, im kinda thinking turbo's now after seeing Ants in action today.
tylerma
Post Sun May 21, 2006 8:10 pm
d6dph wrote:Good work fella. Will have to pop over to see this, im kinda thinking turbo's now after seeing Ants in action today.
lol
nice one Mark
glad to hear its sorted
must get a passenger ride soon dude
Morat
Post Fri May 26, 2006 2:48 pm
Very shiny.... so how would you rate the MS install process on a scale of "easy" to "Nighmare"? :)
Ant
Retired Team Member
Retired Team Member
Post Fri May 26, 2006 2:56 pm
Ms install is as easy as any other similar setup
if you can wire a stereo, and read a diagram then no worries.
e30_Turbo
Boost Junkie
Post Fri May 26, 2006 3:05 pm
Morat wrote:Very shiny.... so how would you rate the MS install process on a scale of "easy" to "Nighmare"? :)
It's much easier once you have read the megamanual :D
Install is straightforward and obvious, the setting up is best approached step by step. Once the basics are complete the rest is actually fun.
I also found that once it's fitted and working it all makes much more sense. Stick to one version, one code and learn. Each upgrade has many more features and changes and can cause more headaches than it's worth. Although the new versions are better as in more options better faetures the older settings may not be compatable and you have to start from scratch.
For anyone here who is after MS I would personally have Ant fit and map while you watch and learn, then once you have understood the basics it will mean you can map away at your own speed. you'll get aftersales support, a peach of a map and full control with peace of mind you have a UK based guru just down the road.
Even my misses who couldn't change a wheel on her own car can sit next to me and help me map mine, once I explained it all she knew what too look for and away she went!
Mark.
lentec
Boost Junkie
Post Fri May 26, 2006 4:01 pm
fozzymonster wrote:Even my misses who couldn't change a wheel on her own car can sit next to me and help me map mine, once I explained it all she knew what too look for and away she went!
Least you can get your misses in the car!!
gcorky
Boost Junkie
Post Fri May 26, 2006 8:18 pm
very good mark,quickie for you and Ant-tach signal whats the crack?
gonna install the ms soon.
525 sport
Ant
Retired Team Member
Retired Team Member
Post Fri May 26, 2006 8:26 pm
use the "tach out" pin from MS mate, should work fine now, been tweaked in the sourcecode
if you are without a wire( cant recall) there are 4 spares in the harness, just pick one and swop it to the required pinout.
gcorky
Boost Junkie
Post Fri May 26, 2006 8:51 pm
me thinx i will have to call you soon.4 spares ,are they connected internally yet?i think you mean open up and solder-yes/no?
525 sport
e30_Turbo
Boost Junkie
Post Fri May 26, 2006 8:52 pm
I've fed my motronic the VR signal so I still have tach. I may have a go with that ms tach signal over the weekend.
Will report back how it goes :D
Ant
Retired Team Member
Retired Team Member
Post Fri May 26, 2006 8:57 pm
G, the wires are connected to the spare outputs on the DB37, I had assumed you'd leave the mronic in place to run the tach, helps with the OBC too mate, but you will need to unsolder one wire and swop it over to the correct pin, only on the DB37 harness though, the MS ecu needs not internal tweaks, I've done them mate :lol:
gcorky
Boost Junkie
fozzymonster wrote:I've fed my motronic the VR signal so I still have tach. I may have a go with that ms tach signal over the weekend.
so your motronic is still powered and active -so youve just wired the ms and left motronic?
head full of college at the mo-will call ya m8 later.
but i think you are saying,wire my ms loom as labelled just leave motronic with injectors ,sensors reqd..etc disconnected and wire them to ms.
525 sport
e30_Turbo
Boost Junkie
Post Fri May 26, 2006 9:04 pm
Pretty much, I plan to remove it all soon but not without enough spare time to patch any other system it powers up and I still need.
I reconnected all the wires I hacked up on install just to be sure any problems weren't due to removing it. So far so good :D
Gunni
Post Tue Jun 06, 2006 2:04 am
whats the ignition timing at idle?
Gunni
@ 2012 VEMS group buy !!
e30_Turbo
Boost Junkie
Post Tue Jun 06, 2006 8:45 am
20 degress or so, I'm yet to really tune it all again due to the car awaiting a new exhaust but as far as I can remember it starts at about 20.
The idle is strong due to a rich mixture so as soon as exhaust is done I'm going to have another play and see if I can't get it spot on.
Cranking sparks are my only issue so far but I'm yet to try any more settings to sort that due to lack of time but I'll get there :D
Have you any experiance with timing tables on M20's?
I'm very interested to know your thoughts on cranking spark settings?
Thanks, Mark.
e30_Turbo
Boost Junkie
Post Tue Jun 06, 2006 7:15 pm
http://video.google.com/videoplay?docid ... 5041967360
Thought I'd take a short vid while I was playing about this evening. Bloody neighbour parked across my garage so I couldn't get it out to open the bonnet, so just me sat in the seat with my toys.
Hopefully some out and about vids soon, real soon I hope.
Mark.
jmc330i
Post Tue Jun 06, 2006 8:35 pm
Looks good, although it sounds more subtle than I was expecting.
Cant wait for the 'out and about' vids :cool:
James
'91 325i Sport
'93 318i touring 16v
e30_Turbo
Boost Junkie
Post Tue Jun 06, 2006 8:47 pm
jmc330i wrote:Looks good, although it sounds more subtle than I was expecting.
I'm still running two boxs until I get my ass in gear and fit a 3 inch single box system but there's a few extra noises when it gets going :twisted:
tylerma
Post Tue Jun 06, 2006 8:54 pm
Mark
sounds sweet matey
if you need somebody to film you doing some fly by's
I am up for it
gcorky
Boost Junkie
Post Tue Jun 06, 2006 9:11 pm
yeah baby love it ,gets the adrenalyn going!!
how loud is your screamer?may fit one yet.undecided?is the h1c ok drivability wise????
wiped mine over today and thought about just fitting the holset from outset. :wink:
525 sport
craigieeb
Post Wed Jun 07, 2006 8:15 pm
Nice1 mark,
it look's good,
cant realy comment on the noise of it, as my sound card is fooked :lol:
and i KNOW you'll love the note off the 3"straight thru, mine sound's just soooo good, so i can sort of imagine the note with a turbo going thu it,
