Megasquirt... just out of interest
Morat
For a normal guy with a 2.5 M20, would it be worth putting MS on to eliminate those idling/flatspot problems and get a nice remap for some extra power?
I thought it would have been really expensive, but looking at some of the vendor sites it doesn't seem to be that pricey afterall.
Are there gains to be had with a day to day car (with a healthy engine) from putting modern fuel injection on an M20? What sort of budget should I allow for MSing a standard M20? I'm absolutely fine with computers (its my job) but a novice when it comes to picking up a spanner. What sensors does the M20 already have, and what would I need to source/fit myself?
Morat
Morat
Ant
- Retired Team Member
good Q's !
with regard to the flatspots, a chip will solve 90% of those without fail, the rar gain with MS or any other standalone is you get the tuning software to play with, and can tweak away until you fell its 100% perfect,
in terms of gains, look at it this way :
power gains, ditching the AFM leaves the intake air unrestricted and as seen on the MAF conversions thats a good 10-15 ponies already, add inthe ability to tune for your specific engines needs and you're on a winner already, you can also add other mods later and retune to suit, or swop in another engine( not neccisarily BMW )
another major plus is you can set the mixture to go lean on part throttle and save a fortune on fuel , mine is turbo charged yet still gets an average or 38 mpg on a long run, and I dont nurese the car @ 70 anywhere, ave speed 85-90 same as everyone else
the setup and software are easy enough to use without exception, add in a dtalogging feature amd full diagnostics and there is o downide imho, apart from the time and small cost.
in terms of sensors, you already have all you need apart from a "proper" tps, £20 from RS or any tps from an M50 engine and you're away.
have a look @ the "1st N/a megasquirt n spark" thread on this forum, there's some info there for you dude.
Email FTW
pf525sport
megasquirt isnt an option on my car is it ant ?
do you think the cossie turbu you fitted would be sufficient for mine & whats involved in fitting it ?
paul
paul
1990 3.6 m5 extended champagne leather 058 rondells etc etc
- Homo Hair
megasquirt would work on the m5.. it doesnt have VANOS..
i think you would have to go bigger than a cossie (standard) turbo - 2.0 vs. 3.6 depending on boost levels you were planning on running
(i am assuming your talking about your m5 btw)
Morat
Thanks Ant
I'm tempted.. broke, but tempted....
FlappySocks
I'm thinking of doing mine soon. I'm quite handy with a soldering iron. Come MOT time, will I have any difficulty getting it through emissions test without being there with my laptop?
Stuart.
Stuart.
Ant
with regard to the emissions... the ability to pass is down to how well tuned the install is, rough running would not bode well, you'd have the ablty to tune to run stoich @ idle ( 1 lambda) with ign timing to suit you can get the emissions lower than stock ( mine are 1 lambda, 289 ppm HC)
Paul( pf525) you could use MS but the M5 has a good adaptive ECU fitted anyways, as long as the MAF readings stay within the 0/5V range through the rpm without pegging out then a remap/piggyback should be fine M8
as for turbo..... lowish boost @ the M5's CR dude, smallish turbo on 3 cylinders only maybe the ideal install, keeps it compact enough to fit in the limited space, and makes finding a suitable unit easier, std 2.0/1.8 turbo T28/T3 size would be spot on then.
food for thought ?
food for thought ?
Email FTW
Templ8e30
I see how you tune the fuel side of the Megasquirt but how do you tune the ignition ?
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
TVRTASMIN
Well definately i'm interested in buying a Megasquirt ECU for my car. What about a group buy from somewhere?
Question might be to buy a kit or one ready assembled. What do you think Ant?
FlappySocks
I just got a quote for a V3 kit (single ignition drive) for £170 delivered from a UK supplier. Does that sound reasonable?
Then I need a TPS and some tubing to bypass the AFM. Anything else (for a fuel only setup)?
Stuart.
Stuart.
Ant
£170 for a DIY kit is spot on, is DB37 and sensors, TPS included @ that ?
Group buy requires some commitment but can be done, minimum I'd suggest is 5 to get any discount.
For fuel only, that is all thats required, but you'll need to tweak the ignition with a chip, and "fudge" a load signal back to the motronic( uses AFM only) in order to get the full 3D map.
Ready assembled units are a lot easier, as you know it works from the outset, but a lot can be learned from the build process, and it all promotes understanding, always good IMHO.
THe tuning side is not too bad, if you can get your mind around the concepts its good fun, and very rewarding, been doing it myself for 5 years, and indeed I tweak on any long trip I get, in pursuit of the perfect map
Go for it fellas, more 'squirters the better, but be aware, you'll soon want to exploit the new tunability
Email FTW
FlappySocks
I'll find out.Ant wrote:£170 for a DIY kit is spot on, is DB37 and sensors, TPS included @ that ?
I assumed setting up the ignition parameters would be more involved, and best left for a later date. Would it be better to wire the ignition up at the same time?Ant wrote: For fuel only, that is all thats required, but you'll need to tweak the ignition with a chip, and "fudge" a load signal back to the motronic( uses AFM only) in order to get the full 3D map.
To be honest, this is the only bit that im not looking forward to. At least that is, getting started with the initial setup. So much to learn!Ant wrote: THe tuning side is not too bad, if you can get your mind around the concepts
Going to get a BBTB at the same time. Do I need to fabricate a bracket or something to attach the TPS to it?
Stuart.
Ant
Ask Ian( BBTB machinist) if you can have an M50 TPS when you order the unit dude, he had a good feew spare last time I chatted with him, you need to fabricate an adapter of sorts but its 3 holes in a flat sheet so nothing major required dude.Going to get a BBTB at the same time. Do I need to fabricate a bracket or something to attach the TPS to it?
HTH
Email FTW
Morat
mmm group buy... but surely we'd be better off with spark as well?
julianm40
will defo be interested in one when ive got a 2.5 lump. What sort of gains are possible with just ms?
Ant
of course you want spark control dude, its the best bit
however, it is possible to implement fuel only and nobble the motronic , gives you breathing space and lessens the steepness of the learning curve..
When I bought my MS, the V2.2 was the "new" version, since surpassed by the V3.0, get a V3.0, although the 2.2 can be brought up to full V3.0 spec for around £50 and some soldering iron action internally.
Anyone thinking MS is the way forward, download Megatune from the MSEFI main site( msns-e ) and have a play around with it, if that baffles you the unit itself may turn into a long term, expensive paper weight.
If anyone want to see a unit in action, try and make a meet around the London area and I'll be happy to show you whats what , and why.
Fozzy is more than capable of showing you the ropes to BTW, he's in Felixstowe area.
Email FTW
FlappySocks
FlappySocks wrote:I'll find out.Ant wrote:£170 for a DIY kit is spot on, is DB37 and sensors, TPS included @ that ?
The kit of parts includes the DB37, but not the sensors or TPS. If anyone is interested you can contact Bill bill@shurvinton.fsworld.co.uk
I told him there are a few of us here wanting to install MS in our E30s. He said if anyone was close to Reading/Fleet, he would be happy to look over the car.
Stuart.
FlappySocks
Cool, thanks Ant. I'll talk to Ian on that.Ant wrote: Ask Ian( BBTB machinist) if you can have an M50 TPS when you order the unit dude, he had a good feew spare last time I chatted with him, you need to fabricate an adapter of sorts but its 3 holes in a flat sheet so nothing major required dude.
Stuart.
JAMZ
Just a question.. why is a diff TPS needed and whats the situation with having a chip installed with using MS..any advantages or disadvantages or does it make no difference at all..
Also,as you can see ive only started reading about this stuff today..Does this unit stay in the car and take place of the ECU or is it just a Plug n Play>program>remove system?
Sry for the n00blet questions but ATM i got no idea on how this works,Very intrested though
Templ8e30
The standard E30 TPS is just a switch to tell the ECU when the throttle is completely closed or wide open with nothing in between. The Megasquirt requires a variable resistance TPS to figure out exactly how much throttle is being used.JAMZ wrote:Just a question.. why is a diff TPS needed and whats the situation with having a chip installed with using MS..any advantages or disadvantages or does it make no difference at all..
The Megasquirt takes the place of the original Motronic engine management which will you'd remove from the car.
Cheers,
Iain T
JAMZ
FlappySocks
From what I have read elsewhere, I think you need to keep the Motronic unit running, to keep the dashboard alive.Templ8e30 wrote:
Stuart.
JAMZ
So im right in thinking with the MS setup it basicaly replaces the restricted Motronic setup in which case the upgraded 'Chip' will be of no use?
Morat
Yes, from what I've been reading MS is a complete fuel injection system with loads more of...well... everything.. than the standard FI that came with the E30. Hardly surprising when you try and remember what sort of computer you could buy in 1984-1991....JAMZ wrote:So im right in thinking with the MS setup it basicaly replaces the restricted Motronic setup in which case the upgraded 'Chip' will be of no use?
Whatever changes you've made to the existing motronic are made irrelevant when you change to MS.
This is all from what I've been reading, I've no real world experience with MS. (yet). Now I'm starting to dream of starting with MS and ditching the flappy air meter, getting a nice map sorted out for N/A running and then thinking about a turbo with boost and launch control from the MS. unf.
Gotta buy a house first tho
JAMZ
Ive got a few changes in mind but il be getting MS even if i stick to orig setup,from what ive read it seems a very good route to go and if you think how much a built setup costs its really a good buy considering a price of a re-map/emerald setup etc..
like you say the setup the e30 uses is farkin old,think i was using a 16 bit Sega back then or the very first nintendo games console to play games on...now my GFX card alone is 256MB..go figure
The £250-300 outlay would pay for the fuel id be saving my tuning this PITA up over the Yr, lol
MS,here we come..... well soon anyway
bottlecapE30
I found this install to give every one an idea of what work is needed to add megasquirt to an e30. i found it to be a great insight and i now belive i can do it myself with a little help Ant.
http://matt325i.home.comcast.net/webpag ... quirt.html
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Morat
Very nice link!
thanks mate
thanks mate
Motronic to Megasquirt Plug and Play Guide
