325i supercharged touring
dips346
London Meets Main Man
Post Wed May 10, 2006 1:38 pm
right half way into finishing the supercharger set up ,still need to lower the compression a little bit ,change the exhaust and work out what pully size i need as its only running 4 psi and pinks a little on full load any help or input welcomed
Nelly
Gumbo
Gumbo
Post Wed May 10, 2006 1:58 pm
Looking sweet there Dips - i "MUST" have a spin in this one day but for now i'll just drool over the pics :drool:
Neil.
"I F**KING LOVE YOU GUMBO"
mason
Post Wed May 10, 2006 2:10 pm
Awesome as always Dips
Looking forward to it coming over my place tommorrow
:bling: :bling:
Mason
bootyman
Post Wed May 10, 2006 2:16 pm
I've been in this car and the power delivery is very nice indeed. Aparrently the V12 is even more savage so i'm looking forward to that winkeye
lentec
Boost Junkie
Post Wed May 10, 2006 2:45 pm
Looks cool take it you moved the alternator to?
What size pulley are you running now?
dips346
Post Wed May 10, 2006 3:34 pm
lentec wrote:Looks cool take it you moved the alternator to?
just the guy ,no the alternator in the same place what i have used is e36 pullys with a shim welded in to give me a extra groove ,going to have take it apart again anywhere to clean and do the gaskets and bits can measure then i was told you might have some pulleys
Jon_Bmw
Dangerous when thinking
Post Wed May 10, 2006 3:35 pm
Looks bling, something Ben would be proud of i'm sure :D
A few questions for you to hopefully help you and me.
Is it running bigger injectors or the standard 325 ones? Standard ones will not cope after about 4500rpm if its anything like my turbo in the early stage. But i'm sure you already know this from your m30 turbo
Why is it running two dump valves, I do like the fact they are re-circ's though, very sleeper.
Whats adding extra fuel if anything, are you still living it up on motronic?
And the question to help me... :wink:
Also where did you get that air filter sock from, i think i need one of them.
Jon
Jon_Bmw
Post Wed May 10, 2006 3:37 pm
Edit i'm a muppet, i think i can see an AFM, top bananna for having it a suck through type, the way it should be :cool:
So you must be running Motronic then?
dips346
Post Wed May 10, 2006 3:40 pm
its running standern injecters but with a single extra mappable piggyback,might get rid of abs for bigger air,it needs twin recir dump valve as it helps it run better
lentec
Boost Junkie
Post Wed May 10, 2006 3:57 pm
dips346 wrote:its running standern injecters but with a single extra mappable piggyback,might get rid of abs for bigger air,it needs twin recir dump valve as it helps it run better
Im running single recirc and one to atmos only open when throttle closed!
I take it there is no clutch on your charger i would have moved the throttle body upstream of the charger as when you start trying to run more boost you will get all sort of problems with pipes popping ect
As for the pulleys im looking into making up a few as theres been a bit of interest recently. just waiting on some prices :cool:
Finny
Post Wed May 10, 2006 11:58 pm
When i actually get my 325 tourer running properly(serious missfire probs at the mo) i plan on slapping a dirty big supercharger on.
As a result i have a couple of questions i would like to ask. There are plenty of people who can give you advice on turbo mods but not too many on the charger front. Right here we go: -
What charger have you used?
How does that arrangement of the AFM work? Is it situated before the charger?( cant work out where the pipes go, sorry).
Did you get a pully made up and fitted to the crank for the charger?
lentec
Boost Junkie
Post Thu May 11, 2006 9:07 am
Finny wrote:What charger have you used?
I have used an M62 from a merc but an M90 or equiv will do.
Finny wrote:How does that arrangement of the AFM work? Is it situated before the charger?( cant work out where the pipes go, sorry).
Yes it runs AIRFILTER-AFM-S/C-T/B. but you have other options
Finny wrote:Did you get a pully made up and fitted to the crank for the charger?
All my own work :D
Ant
Retired Team Member
Retired Team Member
Post Thu May 11, 2006 9:20 am
I like it dips, I like it a lot.
Cant condone the motronic though dude, opportuinty lost there mate, the piggyback can see the boost and up the fuelling but with nothing to retard the ignition she will be prone to pinking, any intercooler in the loop dude ?
good stuff though, didn't realise you'd got this far already dude :cool:
dips346
Post Thu May 11, 2006 9:28 am
Ant wrote:I like it dips, I like it a lot.
no intercooler at the moment these project cars are costing a fair bits now and i havent even started on the cars :cry:
Finny
Post Thu May 11, 2006 9:52 am
Get yourself a chargecooler instead of an intercooler they are a lot more effective as the air doesnt really get that hot on superchargers so you need extra cooling to get a big difference.
Iv seen these fitted to G40s and G60's they use water to cool the air it makes a massive difference.
Ps cheers for the info, im really fancying this project. I always wanted to supercharge one ever since i drove my mates G40 the sound is quality!
lentec
Boost Junkie
Post Thu May 11, 2006 9:55 am
Only problem is that chargcoolers are expensive and few and far between.
bottlecapE30
Post Fri May 19, 2006 3:25 am
looks great i always like the supercharger route as aposed to the turbo. I think your pinking problem is due to the poor fuel injectors. add m30 or m50 injectors and an ajt. fuel reg. that should fix it up.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
