Megasquirt II
TVRTASMIN
Post Thu Apr 06, 2006 6:22 pm
Anybody know if there is a UK supplier or is it best to buy direct from the USA.
I'm after a built unit and does anybody know what else i will need apart from a wideband O2 sensor.
Ian
Ant
Retired Team Member
Retired Team Member
Post Thu Apr 06, 2006 6:28 pm
I can put you in touch with a UK source, excellent quality built units all fully tested etc, drop me a PM for more info, sorry guys, this ones not for public consumption :wink:
Why MS2 ? yes I know the pulsewidth resoloution is better and as standard the unit will supply a PWM idle control valve , Ms1 with the extra code is more powerful and better supported at present, and the idle PWM can be catered for with a few choice component changes.
Be aware that unless you've spent the last few months on MSefi.com, you will be gaining a few grey hairs come setup time, happy to help where I can though fella !
as for the WB02, you only "need" one if you play a full DIY tuneup, any rolling road setup should hve a WB as part of their kit, if thats not the case, run the other way :lol:
HTH
