td 4 oil return sump fitting part no reqd
gcorky
- Boost Junkie
gcorky
- Boost Junkie
Ant
- Retired Team Member
I cant find it either mate, went back through the entire "update" thread looking
Freelander TD4 oil return , same part as 320D e46 though..
approx Ԛ£11 inc the gaskets, you eed to cut about 50mm from the end though and she'll fit sweet
HTH-ish
HTH-ish
Email FTW
Toby_Unna
- Boost Junkie
I spent ages looking through for the landie part no too
if it's same as 320d, does it look like the one here Ant?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=50
gcorky
- Boost Junkie
Toby_Unna
- Boost Junkie
yeah ok i get it now
must be on here somewhere, i'll keep looking
Turbo-Brown
- Boost Junkie
STC4534 is the pipe
8510016 is the gasket
They're Landy parts.
gcorky
- Boost Junkie
