The questions I have are:
What gearbox and lsd to go for? I prefer more acceleration.
Do I need the dipstick housing as well as sump and oil pick up from the e34?
The chap I bought the engine from said that the tailpipe has a butterfly valve in which is controlled from the ecu. Do I have to use that tail pipe or ignore it?
Where do I get a c101 connector from to do the wiring?
It hasn't got a flywheel but I read that you can use a single mass flywheel from an e30. Which model has these? Would my 8v 1.8 have one?
Finally once I have all the bits together, how long roughly would it take to do the transplant? That would probably be the hardest question to answer!!!
