evodan
Post
Fri Feb 03, 2006 10:58 pm
Hi Guys
Am I right in saying you need an E28 535 radiator for a M30 conversion and should it be a direct fit cause mine will not fit in the space as these lugs for the previous rad mounts are in the way. Should I just grind them off or do I have the wrong Radiator? 93 L E30 316 and rad GSF supplied.
Andy335Touring
Post
Fri Feb 03, 2006 11:19 pm
That looks like the right rad.
Yes, you have to grind one of the old lower mounts off.
evodan
Post
Fri Feb 03, 2006 11:27 pm
Cool thanks Andy, Is yours just mounted by the top lugs or is it fastened at the bottom of the rad in anyway?
bigdek
Post
Fri Feb 03, 2006 11:36 pm
you will need to secure it at the bottom somehow or it can potentialy hit the front pulley as it will not be rigid just bolting at the top
Andy335Touring
Post
Fri Feb 03, 2006 11:43 pm
bigdek wrote:you will need to secure it at the bottom somehow or it can potentialy hit the front pulley as it will not be rigid just bolting at the top
dito what he said
evodan
Post
Fri Feb 03, 2006 11:56 pm
thanks Guys, will have to come up with some clamps or something.
gareth
Post
Sat Feb 04, 2006 8:21 am
i found this yesterday!
best to do it with the engine out... i removed most of my knuckles doing it with the engine in!
Ritchie
Post
Mon Feb 06, 2006 12:56 pm
I used the rubber mounts and speed clips from my (now unused) oil cooler to mount the top of my rad and heavy duty cable ties on the bottom. Fit perfect and looks neat.
