help needed
kert6
hello, im new in here and my english isnt very good. my problem is that i had bmw 318 66kw and i putted in there 325 126kw engine. now i have a problem with the wires. does enybody have pictures or something how the wires should be. i hope you understanded what i need.i need to now what wire is what. like (brown-ground).i need car electrical systems sketch.thanks.
stulane
If its an m20 engine does the m20 325 loom not connect directly to the e30 connector??
I didnt know they have different connectors for each engine, thought each loom would just connect to the car connector as the engine loom is pretty inclosed with the ECU connected to it.
Dunno, any suggestions?
kert6
problem is that 318 66kw is karburator engine and there is less wires then 325.
kam-325i
Then you will need to get the ECU/loom from the donor 325i....kert6 wrote:problem is that 318 66kw is karburator engine and there is less wires then 325.
kert6
ecu is allready installed, now i need wires sketch.kam-325i wrote:Then you will need to get the ECU/loom from the donor 325i....kert6 wrote:problem is that 318 66kw is karburator engine and there is less wires then 325.
