m20b20 upgrade options
ludavic
Post Mon Jan 23, 2006 9:06 am
hi all,
I am driving a m20b20 e30 and I need info on the following can anyone tell me briefly the pros and cons of each in terms of cost, horse power, fuel efficiency and etc, thanks:
1) Using a b25 Throttle body and Manifold in my car.
2) Using a b25 engine but with jetronic configuration, is this possible?
Post Mon Jan 23, 2006 9:17 am
Only one of three things is worth doing to the M20B20 engine in an E30.
1/ Leave it alone and enjoy it as it is.
2/ Attach the head to a 525eta, 2.7 litre bottom end.
3/ Swap it for a M20B25.
Anything else is just messing about for very little improvement.
Cloggy Saint
Post Mon Jan 23, 2006 9:19 am
Is the 2.5 TB not a worthwhile mod? It better be cos i'm waiting for the parts in the post!
ludavic
Post Mon Jan 23, 2006 9:23 am
Brianmoooore wrote:Only one of three things is worth doing to the M20B20 engine in an E30.
what are the power benefits of 2? And you can't put a motronic b25 engine into a jetronic system then.
Post Mon Jan 23, 2006 9:38 am
Benefit of 2 is that it produces an engine with a few more HP than a 2.5, but a shed load more of torque.
You can put a montronic into a jetronic and vice versa, if you change over all thats neccessary.
Ant
Retired Team Member
Retired Team Member
Post Mon Jan 23, 2006 9:43 am
option 2 is a bolt on 70 BHP dude, about the same in extra torque too
you know it makes sense winkeye
ludavic
Post Tue Jan 24, 2006 3:42 am
Thanks guys for the advice. From where I'm from in Malaysia, we rarely have ETA engines coming in here and 2.7 litres are rare, most of the half-cuts and engines are from Japan. A b25 engine without the elctronics is about USD 315 to 473. I was wondering if I could plonk it in first withthe eletronics and then later fill the original b25 electronics slowly :) money is the issue ... but of course most guys in the local forum here said to just get a half-cut and cut all further problems off.
