Rover V8 into M40 318i
Looking to do this swap, will be a non EFI V8 and it'l probably be running holley carbs or similar! Does anyone know if there is a kit to buy to fit this in (engine mounts, bellhousing etc). Also what would the the best gearbox to use??? Doubt a standard bm box would last!!
Think a zoner has done this conversion before, is it Kos?
Sure I've seen pics of one with throttle bodies on it
I would have thought you are gonna be into Type 9 'box or maybe a T5 from a Cossie. The getrag is a sturdy old beast good for 300bhp i reckon, turbo lads on here are having no probs with standard drivetrain. Beemer box has fixed bellhousing though
Ant
- Retired Team Member
- Contact:
Hmm, nice swop option
I think I'd use the Rover eng and box, and use the front half of the rover prop with a BMW rear section added, got to be the easiest option , sherpa gearboxes fit too I'm told
As for the carb option, you'll need to change the fuel pump from the EFI type to a pusher facet or similar, there are no regs that can reduce 5 bar (ish) down to the 5psi or so required by the carb
other options are use the bell adapter for a sierra box, adds to the costs though
how about a small block chevy swop ? same work , better result similar costs using used parts
HTH
HTH
Email FTW
Dan318-is
twas dips 346, a mate of Kos. was a rover v8 mate. mite have even been turbo'd or somethign?E30BeemerLad wrote:Think a zoner has done this conversion before, is it Kos?
Sure I've seen pics of one with throttle bodies on it![]()
them boys r off their nuts!
- Kos
- Contact:
look at the top right of the photo, you can just about see it, the RHD e21 had a similar set up i think??
dips you would know about e21's!!??
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
OllieB
- Contact:
Shit loads more torque than any E30 engine though mate. besides, the BM box will not mate to the V8 Engine apparently anyway.pete1979 wrote:a bm box is more than strong enough v8 only has 150 bhp
I'm too scared to drift properly......
jaistanley
A guy called Wayne is the man to talk to.. He uses the BMW owners forum I beleive.
He owns the orange LS1 powered M3. The engine previously in there was a Rover V8 on throttle bodies (the one from the Picture?). He recently threw away the mounts and said I could have had them if he hadn't! Typical.
Good luck. - Should be a nice conversion as the engine is very light. Don't expect huge power though. The Rover V8 is good but hard to get big numbers out of.
Jai
Jai
- Kos
- Contact:
here is a link to a previous thred about v8's with a basic spec id dips enginedips346 wrote:yes it is with a lot of tvr stuff and and engine is well workedzimmerman wrote:yes but Dips your engine aint a Rover is it?
http://www.e30zone.co.uk/modules.php?na ... light=spec
bottom of page 1
IG Pukar.Designs
IG Pukar.Designs
