m50 engine mounts
pete1979
- Boost Junkie
looking for info on engine mount to fit the m50/e30 if anyone knows where i can get some and how much before i start making some cheers people
Andy325i
To quote Ian:
I used these:
11 81 1 128 932 - Left - approx Ԛ£18
11 81 2 225 201 - Right - approx Ԛ£28
You can see what they look like in this picture:
Andy
I used these:
Andy
pete1979
- Boost Junkie
and what mounting brackets did you use just std 325 or i hear a lot about e36 but unsure?
Andy325i
Use the M50 ones
The rubber mounts on the M50 may be useable, but can't verify this, as I used the E28 M5 ones mentioned above
Andy
Andy
Toby_Unna
- Boost Junkie
e36 six cylinder alloy brackets.
this has been asked lots of times before, try searching for M50 mounts using the search function, it'll pull up 15 or so threads. better than asking the same question over and over again
