what clutch for my 2.7 converiosn?
liam012
hi - a friend of mine works in a garage and can get me a sachs clutch kit at cost - does anyone know what clutch would be be the best to get - i'll be running a 2.7 block 2.0 flywheel and 2.5 gearbox. do i just ask for the e28 525e clutch kit?
standard clutches can take alot of grief
liam012
thnks i had heard that but i dont know if i will have problem fitting say a e28 325e clutch or e30 325i or e30 320i clutch? i just want the thickest that'll fit!
m-dtech
- Unapproved Trader caution
they are the same are they not ?
m20 - gertag gearbox
liam012
well i am certain the engine is m20 - i dont think the gearbox goes by the m20 code though and i know the 2.0 and 2.5 sport gearboxs are different as i had to buy one for this convrsion - i am wonderiung will the fact i will be running a 2.0 flywheel affect what clucth to get? maybe a hybrid setup is needed?
Templ8e30
A standard 325i clutch will suffice, the 320i clutch is the same diameter but with less clamping force.
The 525e was always auto hence no clutch kit available.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
e30_Turbo
- Boost Junkie
liam012
good god i forgot about the auto bit!!
cheers
cheers
