Pullys for crank sensor on 2.7 Eta
m-dtech
Unapproved Trader caution
Post Tue Nov 29, 2005 12:38 pm
anyone have the bits i need to swap from gearbox to front pully sensors ?
cheers
mike
lentec
Boost Junkie
Post Tue Nov 29, 2005 1:39 pm
What you need is the vibration damper/trigger sensor mount from a 5series M20.
Im sure you can use the front pulley from a 4cyl if you use the trigger from the 4cyl as it has an extended magnet peice.
HTH
Templ8e30
Post Fri Dec 02, 2005 8:04 pm
I have a spare toothed timing wheel lying in the shed, PM me if you want it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
