I think all i need to use with my Emerald ECU and a lap top is the LC-1 as i don't think i need the data logging memory of the LM-1 as thats taken care of with the ECU and lap top ?
Is that correct or am i being a muppet and misunderstanding it ?
I hope i only need the LC-1 as its quite a bit cheaper than the LM-1 !
The demo videos on their web page are good, worth a watch as i learned that with the data logging you can measure improvments in acceleration when you change the fueling for WOT. You do this by doing a WOT pull in say third from 1k rpm through to the red line, keep an eye on the time it's initially taken to do the pull and try to adjust out any bad fueling. Repeat the WOT pull and recheck the time it took and AFR's to see if it has improved or not.
It will be a bit tricky to do this on the road but i'm sure we could all find a nice quiet road so as not to be a problem to other road users
