yup, that's be a typo!
what diff ratio would mine have? (it's a standard 1990 325i tourer and has a LSD). if i need to replace the diff for a new ratio, my old one is fine so can be sold on. so that's not the end of the world. i'll just have a go first. is it something to do with a 1:1 5th gear on the M30 and an overdrive 5th gear on the M20? it rarely/never goes on a motorway and this concversion will be purely about cheap performance so a short ratio will not be too bad for me... i think!
my thinking with the E34 rad is that it would allow more room down the sides for boost hoses, should i head that route! however, if the E28 535i one simply fits in i may just do that instead!
i have new M20 rubber mounts already. are they the same as the M30 ones?
i have a few cone filters lurking so i'll probably just use one of them to get me up and running at least.
i have got a 205 gti single fan and and citroen bx 16v twin fan setup lurking so there should be one in there that'll do it. how should i do the switching on it? i know kenlowe do kits for this but i'd rather rob something from another car! did bmw do anything with an electric fan?
so lets start
the shopping list! (worst case on everything!)
~ E34 535i to cannibalise (hopefully paying for itself with the leftovers!)
~ taller ratio diff? (i'll try mine first)
~ E28 535i radiator (maybe use E34 one... i'll decide once i have it)
~ E28 535i bottom radiator hose (if using E28 radiator)
~ M30 rubber engine mounts? (maybe reuse the E34 ones or my new E30 M20 ones)
~ gearbox rubber mounts (maybe reuse if the're ok)
~ cambelt
~ oil, filter
~ pas and alternator/water pump drive belts
~ water pump (every bmw engine i've owned so far has had this fail on me!)
~ cone filter (should have one that'll do. or reuse the E34 airbox...)
~ clutch (check condition, maybe reuse)
~ cooling fan (i should have one that'll do it)
~ thermostatic switch setup for fan
~ modified propshaft (make one out of the two)
~ guibo drive coupling (maybe reuse the M30 if it looks VERY good)
~ M30 conversion engine mounts
~ new hoses where required (depending on condition of donor parts)
