BRAKE UPGRADE ON M30 3.5i E30
Rich25i
Post Wed Nov 23, 2005 5:24 pm
Hi just need a bit of help with the brakes now. What would you reccommend for this engine conversion? Upgrade to E34 535i brakes? or a big disk kit?
Rich
Andy335Touring
Post Wed Nov 23, 2005 9:16 pm
E34 brakes won't fit with out a LOT of work.
Standard discs and pads are fine for road use, if not then look in to some sporty pads/uprated fluid/steel braided brake lines.
With some big brake kits you will have to change your alloys up to 16's or 17's so it can be very expensive !
fuzzy
He who sleeps with "Gingers"
Post Wed Nov 23, 2005 9:50 pm
ive got the standard size ebc drilled grooved discs with ebc red stuff pads on all around on mine and they are up to the job no problems, and im running quite high power ...for an e30. winkeye
Rich25i
Post Thu Nov 24, 2005 11:36 am
Thanks Again for your help
