Running an m30
Gwynleym10
Post Thu Nov 17, 2005 5:04 pm
Can any of you m30 people give a vague idea of m30 running costs?
Mainly fuel is it much worse than a 325i? I know its all relative to how you drive it but a rough idea would be nice.
Its chain driven so no cam belt, but any worries with then chain/tensioner?
Spark plugs are cheaper ones than m40 engines! (ok two more need but still...)
Do you use e30 fuel filters? or are they the same as e34?
Gearbox/clutch problems?
Seen a couple wich have thrown a bottm end bearing now, is it a major problem?
Head/gasket problems like m20?
Its basically an m10 and a half and that was always pretty reliable!
Any other problemos?
thanks
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
Andy335Touring
Post Thu Nov 17, 2005 9:51 pm
Gwynleym10 wrote:Can any of you m30 people give a vague idea of m30 running costs?
I get about 100 miles to 25 quids worth of juice, but this is mainly shortish trips to and from work. If you can keep to a sensible speed on the motor way then long trips are a lot better for MPG. Mine isn't a standard lump and it is slightly to short geared to get good MPG so it's may be not a good example.
No probs as such in this area though as a precaution i would put some new chain guides on as they can go brittle(plastic).
I'm using an E30 325 filter
Gear boxs are as tough as nails, it basically the same box as the E30 325. No obvious problems with the clutch.
Me and Toby have just been very unlucky, normally bullet proof
Heads don't crack like the M20, gaskets can go as on any other engine
thanks
Have a read of this page and the forum attached to it
http://www.bmwe34.net/E34main.htm
