I have the ecu from Chu346 old setup which was running boost.
bit confused on the wiring, its a MS1 v3 board i think it was running ms2 extra code.
the cables loose are:
On the 37 pin connector, pins 25, 27, 29, 31 and 36 have loose cables coming out of them.
Underneath the PCB there is a fet transistor 3 legs on it,
There's a red cable and resistor from the leg to JS2 on the left leg, in the middle there is a cable lose and on the right leg a black going to the ground above the proto area.
There is also a connection from +5v above the proto area to JS9 (+12C) to a loose cable.
If you could help me further on this as I'm stuck what goes where.
he did have boost control, i think he had wasted spark at the time and was trying to get the icv to run. I want to no how to wire them in.
where does the air intake temp plug into?
http://www.e30zone.net/modules.php?name ... sc&start=0
Megasquirt wiring
cypriot_boy_2k7
Can this be moved to the forced induction section mods
cypriot_boy_2k7
Thanks will, I'm going to worry about this when I've put the engine back in.
