2.7 Conversion *head choice*
m-dtech
Unapproved Trader caution
Post Mon Nov 14, 2005 8:23 pm
ok i have just taken the 2.7 out the e28 and dropped it in the e30.
the 2.7 has a 200 cast head.
i have a 731 cast 2.0 head from e34 motronic...
will this work ?
Andy_magic
Post Mon Nov 14, 2005 8:42 pm
The 731 head I used was from a motronic 320i so as long as these are the same then yes it will work.
m-dtech
Post Mon Nov 14, 2005 10:49 pm
andy, talk to me... how does she drive ?
does it give hot runny goo down the leg ?? !
Andy_magic
Post Tue Nov 15, 2005 12:24 am
It's certainly a massive improvement over the 320i's original lump.
My car is running the standard 320i fuelling etc still so it's not going to perform as well as it should. I will be fitting AFM/TB/Injectors from a 325i and a zone 2.7 chip when finanaces are better.
At the moment it will do 0-60 in 7.5 seconds, it will hit the rev limiter in 5th and the fuel consumption has improved slightly due to the engine not having to be worked so hard.
Heres a link to a video I shot a couple of weeks ago:
http://mysite.wanadoo-members.co.uk/e30/videos/0260.wmv
The most noticable improvement is torque, the car is so much easier to drive but still pulls happily at higher revs.
Respect is needed in the wet though, I've had a few brown trouser moments so far. :lol:
Post Tue Nov 15, 2005 12:31 am
dude - thats pretty damn rapid considering its only running 320i nonsense!!
wonder if i got a beater 525e and dropped a 320 head and 2.5 inlet on.. :lol:
gcorky
Boost Junkie
Post Tue Nov 15, 2005 9:12 am
what dif is in the vid car andy,seems very low geared?
m-dtech
Post Tue Nov 15, 2005 10:31 am
mine is running all the 2.7eta gear on the auto box
although i have jenveys sitting ready and this 731 head...
Project_E30
Post Tue Nov 15, 2005 1:09 pm
Andy_magic wrote:It's certainly a massive improvement over the 320i's original lump.
Your vid askes for a user name and password?
Andy_magic
Post Tue Nov 15, 2005 2:00 pm
It does feel quite quick, that video was shot with loads of tools in the boot plus a load of ICE.
The diff is the standard 4.11:1 small case, although its starting to moan a bit, but I think thats down to the milage as I don't abuse it with donuts etc (much :lol:)
As for user names and passwords, there shouldn't be any as It's on my webspace thats open to all. Try right clicking the filename and 'save as'
nikos
Post Tue Nov 15, 2005 2:22 pm
go to the link, I uploaded the 2.7 article of total bmw. I hopethe printing quality is good otherwise let me know I can always fax it if sobody wants it
http://pg.photos.yahoo.com/ph/ngranitsa ... .dir=/adea
1991 325 cabio t/c 3.2 evo, 6speed, e36m3 rack, adj bilstein,
http://s241.photobucket.com/albums/ff262/granitsas/
m-dtech
Post Thu Nov 17, 2005 11:46 pm
love the mpg gauge! ::P
Post Thu Nov 17, 2005 11:49 pm
:lol:
Notice you didnt give it full beans in 1st either.. still had over 500rpm left..
I demand that you go out and do it again properly this time :wink: :cool: :twisted:
Kramer
Post Fri Nov 18, 2005 1:34 am
nikos wrote:go to the link, I uploaded the 2.7 article of total bmw. I hopethe printing quality is good otherwise let me know I can always fax it if sobody wants it
I can't read it
nikos
Post Fri Nov 18, 2005 4:57 am
I cant upload better quality The article is on total bmw, october 2004 send me your addres and I will mail it, nikos
Andy_magic
Post Sat Nov 19, 2005 10:45 am
TBH due to it still running 320i ECU etc it goes a bit flat over about 5500rpm, I will post another PROPER video when I've sorted all that out. Plus I'll get someone else to hold the camera :lol:
I saw a 318 turbo automatic video a while back where the econometer dropped all the way to the right when booting it :lol:
Ant
Retired Team Member
Retired Team Member
Post Tue Nov 22, 2005 10:31 am
318 turbo auto, funny you should mention one of those Andy
Coming soon to a forum near you .................. :twisted:
320Touring
Post Tue Nov 22, 2005 10:44 am
ant wrote:318 turbo auto, funny you should mention one of those Andy
http://home.att.net/~jroal/jay/bmw.htm (as pilfered from the links on this very forum....)
oze30
Post Tue Nov 22, 2005 2:43 pm
so if you get a 525 eta, you can bolt a 320 head straight on? no need to change pistons/etc?
Ant
Retired Team Member
Retired Team Member
Post Tue Nov 22, 2005 2:52 pm
cheap torque monster 2.7 built, in short.....
Eta complete bottom end
320i head and cam(731 casting not 200)
325i intake,TB,AFM and injectors
3.0 Bar fuel reg
2.0/2.5 flywheel
you must swop the pilot bearing over, the eta cranks dont have one as std( being auto )
The above should give approx 190lbs/ft everywhere and about the same peak HP too
best conversion for the M20B20 runners, its a bolt in 70 bhp almost !
oze30
Post Tue Nov 22, 2005 2:55 pm
right.. might start shopping!!!
Anyone have a full 320 head for sale?? winkeye
nikos
Post Tue Nov 22, 2005 5:03 pm
the eta head and the 320 are the same unless you port the head and use biger valves and the other problem is the intake manifold and the throtle body which dont give the power you need
nikos
oze30
Post Tue Nov 22, 2005 5:06 pm
Nikos..
So what your saying is, the 320 head is the same number as the eta? Do you have to port the head and bigger valves?? I have a 325 atm.. so most of the ancillaries will com efrom there.
Post Tue Nov 22, 2005 5:15 pm
nikos wrote:the eta head and the 320 are the same unless you port the head and use biger valves and the other problem is the intake manifold and the throtle body which dont give the power you need
nikos
i dont think it is the same.. otherwise surely the eta would produce 190bhp...
m-dtech
Post Tue Nov 22, 2005 6:37 pm
the eta has a casting of 200 though ??? hmmm
we soon see !
nikos
Post Tue Nov 22, 2005 6:47 pm
the eta was restricted because it used the 320 head and manifold although the capacity was 2.7. When you do the conversion you actualy use the eta block but with the 325 pistons and the 325 head and manifold.
The pistons work with the eta conrods. On earlier 325 you have to skim the lower part of the pistons On models later than 1988 you dont have.
Post Tue Nov 22, 2005 6:48 pm
budget build is eta bottom end, 320i head, 325i inlet/loom/ecu
supposedly good for 190bhp..
cam maybe..
Andy_magic
Post Tue Nov 22, 2005 8:25 pm
The ETA as far as I know has a 200 head casting, with only 4 journals for the cam (less drag) and a suitable cam for the 4.5k rpm limit, white injectors and limited at about 4.5k rpm. Loads of torque but no revs (not as we know it anyway)
Sticking the 320i head on gives a vast improvment with regards the camshaft, I think the valves are the same size as the ETA.
Unless your going for out and out power whilst keeping it M20 then the cheap option is a good one, the last 30bhp of 210 is expensive to find.
Just my 2p worth
nikos
Post Tue Nov 22, 2005 9:02 pm
the first conversion I did, was the cam the chip and a filter on a plain 325. I didn t use springs with the cam. The engine reved nicely and I kept in pace with the s3 audi being a litle slower. I believe this is the best modification and worths every penny. If you want to go faster you add a shorter dif. and thats all. It is correct that the last 20 horses you pay them like arabian. Although now I have an extremely fast 2.7 If I knew the cost I would go for the e36 m3
