Well I had thought they'd need to be done seperately, but it seems that both actuators can be connected to the same solenoid valve and the ECU can then regulate the pressure generated by both
I'm hoping that mapped boost should give more midrange grunt as the engine should be able to tolerate more boost at lower speeds, dwindling down to 7psi at the top end
