E36 328 Rad question
blue30
Post Sat Jan 21, 2012 4:36 pm
Just wanted to check, the rad I've got in mine is a Nissens one and it just has one level mark about 1/2 way up the end tank.
Is that a max or a min or what?
TIA
Post Fri Jan 27, 2012 9:25 am
It's the 'max' or correct level for a cold engine. I.E., the level to which you should fill it.
A lot of BMWs seem to settle about 1/2" lower than this, and this is fine as long as it doesn't continue dropping.
blue30
Post Fri Jan 27, 2012 5:53 pm
Cheers dude.
