325ti swap???
pel
Post Fri Jan 06, 2012 7:25 pm
Hey everyone, Iv got hold of an 02 plate E36 325ti compact and was wondering how much trouble it would be swapping it into my old e30? has anyone used one of these engines for a conversion before? any advice would be greatly appreciated. Thanks.
alpina123
Post Fri Jan 06, 2012 7:34 pm
never heard of a 02 ploate e36 you mean the m54 e46 engine
pel
Post Fri Jan 06, 2012 7:39 pm
Sorry silly mistake, it is the e46.
Post Fri Jan 06, 2012 8:57 pm
I would guess that engine will be the M52 B25TU with double vanos. It can be done, but a monumental ball ache due to massive wiring complexity
Post Fri Jan 06, 2012 8:59 pm
Why would you want to ruin a perfectly good turd ? I.E the 325 TI :?
Post Fri Jan 06, 2012 9:09 pm
E30BeemerLad wrote:I would guess that engine will be the M52 B25TU with double vanos. It can be done, but a monumental ball ache due to massive wiring complexity
M54B25.
Post Fri Jan 06, 2012 9:20 pm
M54B25.
:o: :D
pacerpete wrote:Why would you want to ruin a perfectly good turd ? I.E the 325 TI :?
+1, fck the E30 get an E46 M3 donk/axles in the compact! :)
pel
Post Sat Jan 07, 2012 8:07 am
The compact is a write off it was hit up the arse, got it very cheap on the off chance i could use the engine because its only covered 51,000 miles. do you guys think it would be a total nightmare to fit?
Post Sat Jan 07, 2012 11:04 am
Physically fitting the engine isn't too much of a nightmare, with the right sump etc it will drop straight onto the E30 subframe/mounts.
it is the wiring which is the nightmare, I believe the electronics associated with your engine will run the CANBUS system, which means the ECU wants to see signals from sensors all over the car, which is where the average DIY mechanic would be way out of his depth.
Kieran_n22
Post Sat Jan 07, 2012 11:09 am
Any pictures of the damage? Is it a Cat C?
