e36 OBD1 wiring harness
Bimmmers
Post Thu Dec 29, 2011 2:30 pm
how you indentify which year you have, I have a obd1 harness, not sure of which year I have in order to trouble shoot in the electronic manual.
The blank slots are 1, 2, 3, and 9.
I am doing a s52 OBD1 conversions. Thanks.
Post Thu Dec 29, 2011 5:00 pm
Why are you converting it? The Siemens ECU is much better :?
Bimmmers
Post Thu Dec 29, 2011 8:10 pm
mroe horsepower with a obd1 setup, sticking with a 413 dme.
Bimmmers
Post Thu Dec 29, 2011 9:05 pm
siemens ecu better in which way???
Post Thu Dec 29, 2011 9:23 pm
The Siemens can be mapped as much as the Bosch, in standard form the Bosch 413 will not run right at all and be a massive downgrade, if your going to have it mapped then fair enough but your just making work for yourself IMO
Bimmmers
Post Fri Dec 30, 2011 1:54 am
Thanks for the info.
How do I identify the wiring label I have?
Post Fri Dec 30, 2011 9:10 am
No idea, ive never looked at the labels before. As long as its from a vanos engine though they are pretty much all the same
