Is it available so I can get on with fabricating a turbo manifold. I'll be going 2.7 low comp with some nice pistons and probably running a Garrett T28 turbo for now. Only aiming for a reliable 300bhp and don't want too much lag.
If you could let me know where I can buy said flange I'll be a happy bunny. Thanks in advance
James
Exhaust manifold flange for M20B25 engine
ian332isport
I guess they are probably not the cheapest, but I'm pretty sure Demon Tweeks can get manifold flanges cut if you supply them a gasket as a template.
I'm 99% sure it used to be in their Motorsport catalogue.
Cheers,
Ian.
Cheers,
Ian.
Turbo-Brown
- Boost Junkie
I had some made up a while ago.
Had them done in pairs for cyls 1-3 and 4-6.
Seem to recall they were about Ԛ£40 a pair or so, but I had three sets made which brought the cost down a bit.
Check that the gaskets are a decent match because they rarely seem to fit perfectly.
Driftybolox
I wonder if it would be possible to put a gasket onto a scanner, scan it in and then export it somehow to a CNC mill? That would be rather cool if it works like that!
